Unexpected output of M114 with ABL ON
I just discovered that right after homing with G28, M114 reports X position that is off by 0.19 mm. Y and Z coordinates are correct.
My "Park Position X" in EEPROM is -53.5 while M114 shows -53.69.
SENDING:M114
ok 0
X:-53.69 Y:343.00 Z:149.301 E:0.0000
ok 0
I tried multiple times and the result was always the same. Then I disabled ABL in EEPROM and the value changed to -53.5, which was what I expected.
Not sure if this a bug.
I'd appreciate if somebody runs G28 M114 with and without ABL and shares the results.
SENDING:M114I am running the latest 1.x Dev version of firmware on IDEX printer.
ok 0
X:-53.50 Y:343.00 Z:149.301 E:0.0000 ok 0
In your beginning you mix homing and park position which are 2 different things and positions. Homing happens per motor so it does not move using rotation. Therefore the position reached is then transformed after homing into real coordinates which can differ depending on the bed rotation from what you wanted. So in your case you have minimal x rotation which multiplied with z=149.3 gets 0.19 in addition. With z=0 you would not have noticed a difference.
As for you explanation, it sounds like irregularities of bed along Z coordinate defines X. I thought it is other way around. But that's fine, I decided to finally switch to version 2 and won't be further investigating/testing this issue.
Thanks.
