Is there any plans to add support for the VIKI 2 Graphic LCD by Panucatt Devices for Repetier Firmware? If so is there a time frame on when support will be available?
It is already supported for a good time for several boards as described in the viki 2 connection scheme. Just select it in online config tool and wire as described in viki 2 connection scheme.
Check the ui.h Viki 2 radds section for pins. The Viki 2 works, but only without sd card. Didn't get t working with the shared spi for sd card and lcd.
