hole not printed curaengine
HI I'm trying to print simple nut for test purposes but the problem is that there's no hole in the middle of the nut when I slice it
with CuraEngine ! but when I slice it with slic3r there's hole as should be ...
I wonder what is the reason for that problem ...
I want to use Curaengine because it has more options
please advice me ... if you will
bestregards
arto from finland
post script: I'll been using CuraEngine before and it worked well ...maybe reason is those windows10 64 bits updates
bestregards
arto from finland
that's it ... thank you very much to solve my problem !
I really tried many thinks to solve this problem ... but now I'm very happy for your good advance ...
by the way I'm working with do it yourself filament maker machine .... so I want it makes old fashion 3 mm filament
to modern standard 1.75 mm filament ... I know there's no sense but I have one roll of 3 mm PLA filament
and one ABS filament and I want to change those rolls to 1.75 diameter filament ... to use with my printer...
maybe later I'll crunch all my waste 3 d printings to 1.75 filaments ...
OK there is no economical sense ... but it's fun hobby ...
but I know it's very difficult and maybe takes long time to work ...
all the best and thank you
