Toggle navigation
Categories
Discussions
About Us
Privacy Policy
Sign In
Home
Repetier-Firmware
Motor Control
Always check endstops do not work with Probe
SimonTAMTA
May 2019
in
Motor Control
So i was trying to find "if" that is changing that, but without results. Can You give any advice where to change it?
Repetier
May 2019
Please define the thats that you want to behave different. Probing/homing doe snot use always check endstops and target tests as it is supposed to go outside it ha sit's own logic here. The rest should respect it.
Sign In
or
Register
to comment.
