Always check endstops do not work with Probe
So i was trying to find "if" that is changing that, but without results. Can You give any advice where to change it?
  • > find "if" that is changing that
    Please define the thats that you want to behave different. Probing/homing doe snot use always check endstops and target tests as it is supposed to go outside it ha sit's own logic here. The rest should respect it.
