CNC Change tool
Hi
I have been trying to turn my printer into a cnc machine I have purchased Estlcam and am using G codes generated by it in Reperier Host.
My problem is at change tool Estlcam uses G codes that repetier does not recognise.
I want to load the code into the printer sd card.
At change tool I want the 1 printer lift z go to home 2 have the lcd report change tool continue when ready.
3 When I press continue the print starts where it left off.
I am using Repetier Firmware
Can you wright the code for me or help I am using the sainsmart lcd.
Hi RAyWB
The code in Estlcam is
; No.2: Drill 2
MO5
MO5
; Change Tool 5MM
MO3
