CNC Change tool
Hi
I have been trying to turn my printer into a cnc machine I have purchased Estlcam and  am using G codes generated by it in Reperier Host.
My problem is at change tool Estlcam uses G codes that repetier does not recognise.
I want to load the code into the printer sd card.
At change tool  I want the 1 printer lift z  go to home 2 have the  lcd report change tool continue when ready.
3 When I press continue the print starts where it left off.
I am using Repetier Firmware
Can you wright the code for me or help I  am using the sainsmart lcd.
  • You can e.g. add a M6 command in commands.cpp. Unfortunately my time frame does not allow me writing such special solutions. LCD output is a bit difficult to integrate and will take most of the time, except if you only change the status line. So I would suggest to do just that. Memory position, move send status message and wait for a button to be pressed. With sole sd card solution that should be no problem with timeout of host software. Otherwise you would need a more complicated solution.
  • Can you post a gcode  section  to see what Estlcam generates for tool change?
  • Hi  RAyWB
    The code in Estlcam is
    ; No.2: Drill 2
    MO5
    MO5
    ; Change Tool 5MM
    MO3
  • Guthrie said:
    Hi  RAyWB
    ; No.2: Drill 2
    MO5
    MOO
    ; Change Tool 5MM
    MO3
    Sorry about that
    Gb
  • ok, so M05 is spindle stop,
    M00 is machine stop
    and M03 is spindle start.
    as far as i know that´s just something like a workaround for a real m6...
    the minor problem is that repetier does not understand the m00.
    what about z-correction for different tool lengths ?
    ist there something estlcam does or do you have to probe?
    next problem is that you have to lift z-axis to change the tool ...
    where is your probe? mobile or fix in table?
    the usual way would be to start with a tool, probe to workpiece to get a Z-value
    for tool change you have to  memory position , lift z ,stop spindle , goto probe ,measure tool length , lift z again , change tool, acknowledge tool change(button), measure new length, correct offset and go back to memorized position.
    that´s what a standard toolchange procedure should do.
    i wrote something like that 2 years ago , but special for my machine may be i can hook it up again
    and make a short video how it works.
    are you located in germany?
    M00 is machine stop
    M00 is machine stop
    M00 is machine stop
