Almost there.... and strange behaviour
So the dev time was nice enough to add the Open Motion Controller to the list and i copied over as many settings from marlin firmware i could
I got Repetier uploaded but its not quite working
All endstops report L as they should when not triggered.
Extruder Fan works
Heat bed works
Extruder works
Now the BIG but:
When steppers should be disabled they are enabled, and when they are not enabled the electronics fan are enabled even thou i belive the fan should not be automatic?
So after the idle time out it enabled the stepper... when i send it a G0 Z1 to move the Z it disables the steppers and turns on the fan.... the steppers do not move
Its the same on the other axes....
The Open Motion controller uses the Toshiba TB6560AHQ drivers
Have anyone ever experienced this?
