Problem using 3 Z steppers and bed leveling
Have finally worked through the configuration tool and think I have set it up correctly (mostly).
Using rads board with 2 extra drivers on extension board.
Have Z1 motor on "Z" stepper pins, Z2 and Z3 on Extruder 3 & 4 pins.
Tried to compile software, got an error
#error You need to define 2 motors for motorized bed correction
How do I do this?
Also using BL touch sensor for probing and Zmin endstop.
I think I have configured it correctly, but if someone can check over the settings, that would be great.
The probe pin is used with Zmin, how is the solenoid pin defined?
Does the M340 P0 define the solenoid pin?
Servo 0 > Digital pin 5 Is this correct?
Following is configuration.h and pins.h files.
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
This file is optimized for version 1.0.3
as you expect.
_______________________________________________________________________
#define NUM_EXTRUDER 2
#define MOTHERBOARD 402
#define RFSERIAL Serial
#include "pins.h"
#undef FAN_PIN
#define FAN_PIN ORIG_FAN2_PIN
#undef FAN2_PIN
#define FAN2_PIN -1
#undef FAN_BOARD_PIN
#define FAN_BOARD_PIN -1
#define BOARD_FAN_SPEED 255
#define BOARD_FAN_MIN_SPEED 0
#define FAN_THERMO_PIN -1
//#define COMPAT_PRE1
#define BLUETOOTH_SERIAL -1
#define BLUETOOTH_BAUD 115200
#define MIXING_EXTRUDER 0
#define DRIVE_SYSTEM 0
#define XAXIS_STEPS_PER_MM 320
#define YAXIS_STEPS_PER_MM 320
#define ZAXIS_STEPS_PER_MM 9070.87
#define PDM_FOR_EXTRUDER 1
#define PDM_FOR_COOLER 1
#define RETRACT_ON_PAUSE 2
#define PAUSE_END_COMMANDS ""
#define EXT0_X_OFFSET 0
#define EXT0_Y_OFFSET 0
#define EXT0_Z_OFFSET 0
#define EXT0_STEPS_PER_MM 495
#define EXT0_INVERSE 0
#define EXT0_ENABLE_ON 1
#define EXT0_MIRROR_STEPPER 0
#define EXT0_INVERSE2 0
#define EXT0_MAX_FEEDRATE 50
#define EXT0_MAX_START_FEEDRATE 18
#define EXT0_HEAT_MANAGER 1
#define EXT0_PREHEAT_TEMP 195
#define EXT0_WATCHPERIOD 1
#define EXT0_PID_I 2
#define EXT0_PID_D 40
#define EXT0_PID_MAX 255
#define EXT0_ADVANCE_K 0
#define EXT0_ADVANCE_L 0
#define EXT0_EXTRUDER_COOLER_PIN ORIG_FAN_PIN
#define EXT0_JAM_PIN -1
#define EXT0_JAM_PULLUP 0
#define EXT1_X_OFFSET 11200
#define EXT1_Y_OFFSET 0
#define EXT1_Z_OFFSET 0
#define EXT1_STEPS_PER_MM 495
#define EXT1_TEMPSENSOR_TYPE 8
#define EXT1_TEMPSENSOR_PIN TEMP_2_PIN
#define EXT1_HEATER_PIN HEATER_2_PIN
#define EXT1_STEP_PIN ORIG_E1_STEP_PIN
#define EXT1_DIR_PIN ORIG_E1_DIR_PIN
#define EXT1_INVERSE 0
#define EXT1_ENABLE_PIN ORIG_E1_ENABLE_PIN
#define EXT1_ENABLE_ON 1
#define EXT1_MIRROR_STEPPER 0
#define EXT1_INVERSE2 0
#define EXT1_MAX_FEEDRATE 50
#define EXT1_HEAT_MANAGER 1
#define EXT1_PREHEAT_TEMP 195
#define EXT1_WATCHPERIOD 1
#define EXT1_PID_I 2
#define EXT1_PID_D 40
#define EXT1_PID_MAX 255
#define EXT1_ADVANCE_K 0
#define EXT1_ADVANCE_L 0
#define EXT1_JAM_PIN -1
#define EXT1_JAM_PULLUP 0
#define FEATURE_RETRACTION 1
#define AUTORETRACT_ENABLED 0
#define RETRACTION_LENGTH 3
#define RETRACTION_SPEED 40
#define RETRACTION_Z_LIFT 0
#define FILAMENTCHANGE_X_POS 300
#define FILAMENTCHANGE_Y_POS 50
#define FILAMENTCHANGE_Z_ADD 25
#define JAM_METHOD 1
#define JAM_STEPS 220
#define JAM_SLOWDOWN_TO 70
#define JAM_ERROR_STEPS 500
#define JAM_MIN_STEPS 10
#define JAM_ACTION 1
#define PID_CONTROL_RANGE 20
#define SKIP_M109_IF_WITHIN 2
#define SCALE_PID_TO_MAX 0
#define TEMP_HYSTERESIS 0
#define EXTRUDE_MAXLENGTH 160
#define GENERIC_THERM_VREF 5
#define HEATER_PWM_SPEED 0
#define COOLER_PWM_SPEED 0
#define HAVE_HEATED_BED 1
#define SKIP_M190_IF_WITHIN 3
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 275
#define X2_MIN_PIN -1
#define X2_MAX_PIN -1
#define Y2_MIN_PIN -1
#define Y2_MAX_PIN -1
#define Z2_MINMAX_PIN -1
#define DOOR_PIN -1
#define DOOR_PULLUP 1
#define DOOR_INVERTING 1
#define ENDSTOP_X_BACK_MOVE 5
#define ENDSTOP_Y_BACK_MOVE 5
#define ENDSTOP_Z_BACK_MOVE 2
#define ENDSTOP_X_BACK_ON_HOME 3
#define ENDSTOP_Y_BACK_ON_HOME 3
#define MOVE_X_WHEN_HOMED 0
#define MOVE_Y_WHEN_HOMED 0
#define MOVE_Z_WHEN_HOMED 0
#define X_ENABLE_ON 1
#define Y_ENABLE_ON 1
#define Z_ENABLE_ON 1
#define DISABLE_X 0
#define DISABLE_Y 0
#define DISABLE_Z 0
#define DISABLE_E 1
#define INVERT_X_DIR 0
#define INVERT_X2_DIR 0
#define INVERT_Y_DIR 0
#define INVERT_Y2_DIR 0
#define INVERT_Z_DIR 0
#define INVERT_Z2_DIR 0
#define INVERT_Z3_DIR 0
#define INVERT_Z4_DIR 0
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define X_MAX_LENGTH 600
#define Y_MAX_LENGTH 600
#define Z_MAX_LENGTH 600
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define PARK_POSITION_X 0
#define PARK_POSITION_Y 10
#define DISTORTION_LIMIT_TO 2
#define DISTORTION_XMIN 10
#define DISTORTION_YMIN 10
#define DISTORTION_XMAX 190
#define DISTORTION_YMAX 190
// ## Movement settings ##
#define EXACT_DELTA_MOVES 1
// Delta settings
#define DELTA_HOME_ON_POWER 0
#define MAX_INACTIVE_TIME 0L
#define MAX_FEEDRATE_X 200
#define MAX_FEEDRATE_Y 200
#define MAX_FEEDRATE_Z 3
#define HOMING_FEEDRATE_X 40
#define HOMING_FEEDRATE_Y 40
#define HOMING_FEEDRATE_Z 2
#define HOMING_ORDER HOME_ORDER_XYTZ
#define ZHOME_PRE_RAISE 2
#define ZHOME_PRE_RAISE_DISTANCE 6
#define ZHOME_HEAT_ALL 0
#define ZHOME_HEAT_HEIGHT 20
#define ZHOME_X_POS 300
#define ZHOME_Y_POS 300
#define X_BACKLASH 0
#define Y_BACKLASH 0
#define Z_BACKLASH 0
#define RAMP_ACCELERATION 1
#define STEPPER_HIGH_DELAY 2
#define DIRECTION_DELAY 0
#define STEP_DOUBLER_FREQUENCY 80000
#define ALLOW_QUADSTEPPING 1
#define MAX_JERK 20
#define MAX_ZJERK 1
#define MOVE_CACHE_LOW 10
#define DUAL_X_AXIS 0
#define DUAL_X_RESOLUTION 0
#define FEATURE_TWO_ZSTEPPER 1
#define Z2_STEP_PIN ORIG_E2_STEP_PIN
#define Z2_DIR_PIN ORIG_E2_DIR_PIN
#define Z2_ENABLE_PIN ORIG_E2_ENABLE_PIN
#define FEATURE_THREE_ZSTEPPER 1
#define Z3_STEP_PIN ORIG_E3_STEP_PIN
#define Z3_DIR_PIN ORIG_E3_DIR_PIN
#define Z3_ENABLE_PIN ORIG_E3_ENABLE_PIN
#define USE_ADVANCE 0
#define BAUDRATE 250000
#define ENABLE_POWER_ON_STARTUP 0
#define POWER_INVERTING 0
#define AUTOMATIC_POWERUP 0
#define KILL_METHOD 1
#define ACK_WITH_LINENUMBER 1
#define ECHO_ON_EXECUTE 1
#define EEPROM_MODE 1
#undef PS_ON_PIN
#define PS_ON_PIN -1
#define STARTUP_GCODE "M42 P67 S0\n M42 P68 S255\n M42 P69 S255"
#define JSON_OUTPUT 0
/* ======== Servos =======
Control the servos with
#define FEATURE_SERVO 1
#define SERVO0_PIN 5
#define SERVO1_PIN -1
#define SERVO2_PIN -1
#define SERVO3_PIN -1
#define SERVO0_NEUTRAL_POS -1
#define SERVO1_NEUTRAL_POS -1
#define SERVO2_NEUTRAL_POS -1
#define SERVO3_NEUTRAL_POS -1
#define UI_SERVO_CONTROL 0
#define MAX_FAN_PWM 255
#define FEATURE_WATCHDOG 1
#define Z_PROBE_Z_OFFSET 0
#define UI_BED_COATING 0
#define FEATURE_Z_PROBE 1
#define EXTRUDER_IS_Z_PROBE 0
#define Z_PROBE_PULLUP 0
#define Z_PROBE_ON_HIGH 1
#define Z_PROBE_X_OFFSET 35
#define Z_PROBE_Y_OFFSET 0
#define Z_PROBE_SPEED 2
#define Z_PROBE_XY_SPEED 150
#define Z_PROBE_SWITCHING_DISTANCE 6
#define Z_PROBE_REPETITIONS 2
#define Z_PROBE_USE_MEDIAN 0
#define Z_PROBE_HEIGHT 1
#define Z_PROBE_DELAY 0
#define Z_PROBE_START_SCRIPT "M340 P0 S700"
#define Z_PROBE_FINISHED_SCRIPT "M340 P0 S1500"
#define FEATURE_AUTOLEVEL 1
#define Z_PROBE_X1 50
#define Z_PROBE_Y1 50
#define Z_PROBE_X2 550
#define Z_PROBE_Y2 50
#define Z_PROBE_X3 50
#define Z_PROBE_Y3 550
#define BED_LEVELING_METHOD 1
#define BED_CORRECTION_METHOD 1
#define BED_LEVELING_GRID_SIZE 6
#define BED_MOTOR_1_X -148.5
#define BED_MOTOR_1_Y 320.5
#define BED_MOTOR_2_X 789.5
#define BED_MOTOR_2_Y 77.7
#define BED_MOTOR_3_X 789.5
#define BED_MOTOR_3_Y 563.3
#define FEATURE_AXISCOMP 0
#define AXISCOMP_TANXY 0
#define AXISCOMP_TANYZ 0
#define AXISCOMP_TANXZ 0
#define SDSUPPORT 0
#undef SDCARDDETECT
#define SDCARDDETECT -1
#undef SDCARDDETECTINVERTED
#endif
#define SD_RUN_ON_STOP ""
#define ARC_SUPPORT 1
#define FEATURE_FAN_CONTROL 1
#define FEATURE_FAN2_CONTROL 1
#define FEATURE_CONTROLLER 7
#define ADC_KEYPAD_PIN -1
#define LANGUAGE_EN_ACTIVE 1
#define LANGUAGE_DE_ACTIVE 0
#define LANGUAGE_NL_ACTIVE 0
#define LANGUAGE_PT_ACTIVE 0
#define LANGUAGE_IT_ACTIVE 0
#define LANGUAGE_ES_ACTIVE 0
#define LANGUAGE_FI_ACTIVE 0
#define LANGUAGE_SE_ACTIVE 0
#define LANGUAGE_FR_ACTIVE 0
#define LANGUAGE_CZ_ACTIVE 0
#define LANGUAGE_PL_ACTIVE 0
#define LANGUAGE_TR_ACTIVE 0
#define UI_PRINTER_NAME "Big Ass Printer"
#define UI_PRINTER_COMPANY "Patton Productions"
#define FEATURE_UI_KEYS 0
#define UI_ENCODER_SPEED 1
#define UI_REVERSE_ENCODER 0
#define UI_KEY_BOUNCETIME 10
#define UI_KEY_MIN_REPEAT 50
#define FEATURE_BEEPER 1
#define CASE_LIGHTS_PIN -1
#define NUM_MOTOR_DRIVERS 0
#endif
"editMode": 1,
"processor": 1,
"baudrate": 250000,
"bluetoothSerial": -1,
"bluetoothBaudrate": 115200,
"xStepsPerMM": 320,
"yStepsPerMM": 320,
"zStepsPerMM": 9070.87,
"xInvert": 0,
"x2Invert": 0,
"xInvertEnable": "1",
"eepromMode": 1,
"yInvert": 0,
"y2Invert": 0,
"yInvertEnable": "1",
"zInvert": 0,
"z2Invert": 0,
"z3Invert": 0,
"z4Invert": 0,
"zInvertEnable": "1",
"extruder": [
"id": 0,
"heatManager": 1,
"pidDriveMin": 40,
"pidDriveMax": 230,
"pidMax": 255,
"sensorType": 8,
"sensorPin": "TEMP_0_PIN",
"heaterPin": "HEATER_0_PIN",
"maxFeedrate": 50,
"startFeedrate": 18,
"invert": "0",
"invertEnable": "1",
"acceleration": 5000,
"watchPeriod": 1,
"pidP": 7,
"pidI": 2,
"pidD": 40,
"advanceK": 0,
"advanceL": 0,
"waitRetractTemp": 150,
"waitRetractUnits": 0,
"waitRetract": 0,
"stepsPerMM": 495,
"coolerPin": "ORIG_FAN_PIN",
"coolerSpeed": 255,
"selectCommands": "",
"deselectCommands": "",
"xOffset": 0,
"yOffset": 0,
"zOffset": 0,
"xOffsetSteps": 0,
"yOffsetSteps": 0,
"zOffsetSteps": 0,
"stepper": {
"name": "Extruder 0",
"step": "ORIG_E0_STEP_PIN",
"dir": "ORIG_E0_DIR_PIN",
"advanceBacklashSteps": 0,
"decoupleTestPeriod": 12,
"jamPin": -1,
"jamPullup": "0",
"mirror": "0",
"invert2": "0",
"stepper2": {
"preheat": 195
"id": 1,
"heatManager": 1,
"pidDriveMin": 40,
"pidDriveMax": 230,
"pidMax": 255,
"sensorType": 8,
"sensorPin": "TEMP_2_PIN",
"heaterPin": "HEATER_2_PIN",
"maxFeedrate": 50,
"startFeedrate": 20,
"invert": "0",
"watchPeriod": 1,
"pidP": 7,
"pidI": 2,
"pidD": 40,
"advanceK": 0,
"advanceL": 0,
"waitRetract": 0,
"stepsPerMM": 495,
"coolerPin": -1,
"coolerSpeed": 255,
"xOffset": 35,
"yOffset": 0,
"zOffset": 0,
"xOffsetSteps": 11200,
"yOffsetSteps": 0,
"zOffsetSteps": 0,
"stepper": {
"name": "Extruder 1",
"step": "ORIG_E1_STEP_PIN",
"dir": "ORIG_E1_DIR_PIN",
"jamPin": -1,
"jamPullup": "0",
"mirror": "0",
"invert2": "0",
"stepper2": {
"preheat": 195
"uiLanguage": 0,
"uiController": 0,
"xMinEndstop": 2,
"yMinEndstop": 2,
"zMinEndstop": 4,
"xMaxEndstop": 2,
"yMaxEndstop": 2,
"zMaxEndstop": 2,
"x2MinEndstop": 0,
"y2MinEndstop": 0,
"x2MaxEndstop": 0,
"y2MaxEndstop": 0,
"motherboard": 402,
"driveSystem": 0,
"xMaxSpeed": 200,
"xHomingSpeed": 40,
"xTravelAcceleration": 1000,
"xPrintAcceleration": 1000,
"yMaxSpeed": 200,
"yHomingSpeed": 40,
"yTravelAcceleration": 1000,
"yPrintAcceleration": 1000,
"zMaxSpeed": 3,
"zHomingSpeed": 2,
"zTravelAcceleration": 100,
"zPrintAcceleration": 100,
"xMotor": {
"name": "X motor",
"step": "ORIG_X_STEP_PIN",
"dir": "ORIG_X_DIR_PIN",
"enable": "ORIG_X_ENABLE_PIN"
"yMotor": {
"name": "Y motor",
"step": "ORIG_Y_STEP_PIN",
"dir": "ORIG_Y_DIR_PIN",
"enable": "ORIG_Y_ENABLE_PIN"
"zMotor": {
"name": "Z motor",
"step": "ORIG_Z_STEP_PIN",
"dir": "ORIG_Z_DIR_PIN",
"enable": "ORIG_Z_ENABLE_PIN"
"enableBacklash": "0",
"backlashX": 0,
"backlashY": 0,
"backlashZ": 0,
"stepperInactiveTime": 360,
"maxInactiveTime": 0,
"xMinPos": 0,
"yMinPos": 0,
"zMinPos": 0,
"xLength": 600,
"yLength": 600,
"zLength": 600,
"alwaysCheckEndstops": "0",
"disableX": "0",
"disableY": "0",
"disableZ": "0",
"disableE": "1",
"xHomeDir": "-1",
"yHomeDir": "-1",
"zHomeDir": "-1",
"xEndstopBack": 3,
"yEndstopBack": 3,
"zEndstopBack": 0,
"deltaDiagonalRod": 445,
"deltaAlphaA": 210,
"deltaAlphaB": 330,
"deltaAlphaC": 90,
"deltaDiagonalCorrA": 0,
"deltaDiagonalCorrB": 0,
"deltaDiagonalCorrC": 0,
"deltaMaxRadius": 150,
"deltaRadiusCorrA": 0,
"deltaRadiusCorrB": 0,
"deltaRadiusCorrC": 0,
"deltaXOffsetSteps": 0,
"deltaYOffsetSteps": 0,
"deltaZOffsetSteps": 0,
"deltaSegmentsPerLine": 20,
"stepperHighDelay": 2,
"directionDelay": 0,
"stepDoublerFrequency": 80000,
"allowQuadstepping": "1",
"doubleStepDelay": 0,
"maxJerk": 20,
"maxZJerk": 1,
"moveCacheSize": 16,
"moveCacheLow": 10,
"lowTicksPerMove": 250000,
"enablePowerOnStartup": "0",
"echoOnExecute": "1",
"sendWaits": "1",
"ackWithLineNumber": "1",
"killMethod": 1,
"useAdvance": "0",
"useQuadraticAdvance": "0",
"powerInverting": 0,
"mirrorX": 0,
"mirrorXMotor": {
"mirrorY": 0,
"mirrorYMotor": {
"mirrorZ": "1",
"mirrorZMotor": {
"name": "Extruder 2",
"step": "ORIG_E2_STEP_PIN",
"dir": "ORIG_E2_DIR_PIN",
"mirrorZ3": "1",
"mirrorZ3Motor": {
"name": "Extruder 3",
"step": "ORIG_E3_STEP_PIN",
"dir": "ORIG_E3_DIR_PIN",
"mirrorZ4": "0",
"mirrorZ4Motor": {
"dittoPrinting": "0",
"featureServos": "1",
"servo0Pin": 5,
"servo1Pin": -1,
"servo2Pin": -1,
"servo3Pin": -1,
"featureWatchdog": "1",
"hasHeatedBed": "1",
"enableZProbing": "1",
"extrudeMaxLength": 160,
"homeOrder": "HOME_ORDER_XYTZ",
"featureController": 7,
"uiPrinterName": "Big Ass Printer",
"uiPrinterCompany": "Patton Productions",
"uiPagesDuration": 4000,
"uiHeadline": "",
"uiDisablePageswitch": "1",
"uiAutoReturnAfter": 30000,
"featureKeys": "0",
"uiEncoderSpeed": 1,
"uiReverseEncoder": "0",
"uiKeyBouncetime": 10,
"uiKeyFirstRepeat": 500,
"uiKeyReduceRepeat": 50,
"uiKeyMinRepeat": 50,
"featureBeeper": "1",
"uiMinHeatedBed": 30,
"uiMaxHeatedBed": 120,
"uiMinEtxruderTemp": 170,
"uiMaxExtruderTemp": 260,
"uiExtruderFeedrate": 2,
"maxBedTemperature": 120,
"bedSensorType": 1,
"bedSensorPin": "TEMP_1_PIN",
"bedHeatManager": 1,
"bedPreheat": 55,
"bedUpdateInterval": 5000,
"bedPidDriveMin": 80,
"bedPidDriveMax": 255,
"bedPidP": 196,
"bedPidI": 33,
"bedPidD": 290,
"bedPidMax": 255,
"bedDecoupleTestPeriod": 300,
"caseLightPin": -1,
"caseLightDefaultOn": "1",
"bedSkipIfWithin": 3,
"gen1T0": 25,
"gen1R0": 100000,
"gen1Beta": 4036,
"gen1MinTemp": -20,
"gen1MaxTemp": 300,
"gen1R1": 0,
"gen1R2": 4700,
"gen2T0": 25,
"gen2R0": 100000,
"gen2Beta": 4036,
"gen2MinTemp": -20,
"gen2MaxTemp": 300,
"gen2R1": 0,
"gen2R2": 4700,
"gen3T0": 25,
"gen3R0": 100000,
"gen3Beta": 4036,
"gen3MinTemp": -20,
"gen3MaxTemp": 300,
"gen3R1": 0,
"gen3R2": 4700,
"userTable0": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"userTable1": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"userTable2": {
"r1": 0,
"r2": 4700,
"temps": [],
"numEntries": 0
"tempHysteresis": 0,
"pidControlRange": 20,
"skipM109Within": 2,
"extruderFanCoolTemp": 50,
"minTemp": 150,
"maxTemp": 275,
"minDefectTemp": -10,
"maxDefectTemp": 290,
"arcSupport": "1",
"forceChecksum": "0",
"sdExtendedDir": "1",
"featureFanControl": "1",
"fanPin": "ORIG_FAN2_PIN",
"featureFan2Control": "1",
"fan2Pin": -1,
"fanThermoPin": -1,
"fanThermoMinPWM": 128,
"fanThermoMaxPWM": 255,
"fanThermoMinTemp": 45,
"fanThermoMaxTemp": 60,
"fanThermoThermistorPin": -1,
"fanThermoThermistorType": 1,
"scalePidToMax": 0,
"zProbePin": "ORIG_Z_MIN_PIN",
"zProbeBedDistance": 10,
"zProbeDisableHeaters": "0",
"zProbePullup": "0",
"zProbeOnHigh": "1",
"zProbeXOffset": 35,
"zProbeYOffset": 0,
"zProbeWaitBeforeTest": "0",
"zProbeSpeed": 2,
"zProbeXYSpeed": 150,
"zProbeHeight": 1,
"zProbeStartScript": "M340 P0 S700",
"zProbeFinishedScript": "M340 P0 S1500",
"featureAutolevel": "1",
"zProbeX1": 50,
"zProbeY1": 50,
"zProbeX2": 550,
"zProbeY2": 50,
"zProbeX3": 50,
"zProbeY3": 550,
"zProbeSwitchingDistance": 6,
"zProbeRepetitions": 2,
"zProbeMedian": "0",
"zProbeEveryPoint": "",
"sdSupport": "0",
"sdCardDetectPin": -1,
"sdCardDetectInverted": "0",
"uiStartScreenDelay": 1000,
"xEndstopBackMove": 5,
"yEndstopBackMove": 5,
"zEndstopBackMove": 2,
"xEndstopRetestFactor": 3,
"yEndstopRetestFactor": 3,
"zEndstopRetestFactor": 3,
"xMinPin": "ORIG_X_MIN_PIN",
"yMinPin": "ORIG_Y_MIN_PIN",
"zMinPin": "ORIG_Z_MIN_PIN",
"xMaxPin": "ORIG_X_MAX_PIN",
"yMaxPin": "ORIG_Y_MAX_PIN",
"zMaxPin": "ORIG_Z_MAX_PIN",
"x2MinPin": -1,
"y2MinPin": -1,
"x2MaxPin": -1,
"y2MaxPin": -1,
"deltaHomeOnPower": "0",
"fanBoardPin": -1,
"heaterPWMSpeed": 0,
"featureBabystepping": "1",
"babystepMultiplicator": 1,
"pdmForHeater": "1",
"pdmForCooler": "1",
"psOn": -1,
"mixingExtruder": "0",
"featureAxisComp": "0",
"axisCompTanXY": 0,
"axisCompTanXZ": 0,
"axisCompTanYZ": 0,
"retractOnPause": 2,
"pauseStartCommands": "",
"pauseEndCommands": "",
"distortionCorrection": "0",
"distortionCorrectionR": 100,
"distortionPermanent": "1",
"distortionEndDegrade": 1,
"distortionXMin": 10,
"distortionXMax": 190,
"distortionYMin": 10,
"distortionYMax": 190,
"sdRunOnStop": "",
"featureRetraction": "1",
"autoretractEnabled": "0",
"retractionLength": 3,
"retractionLongLength": 13,
"retractionSpeed": 40,
"retractionZLift": 0,
"retractionUndoSpeed": 20,
"filamentChangeXPos": 300,
"filamentChangeYPos": 50,
"filamentChangeZAdd": 25,
"filamentChangeRehome": 1,
"fanKickstart": 200,
"servo0StartPos": -1,
"servo1StartPos": -1,
"servo2StartPos": -1,
"servo3StartPos": -1,
"uiDynamicEncoderSpeed": "1",
"uiServoControl": 0,
"killIfSensorDefect": "0",
"jamSteps": 220,
"jamSlowdownSteps": 320,
"jamSlowdownTo": 70,
"jamErrorSteps": 500,
"jamMinSteps": 10,
"jamAction": 1,
"jamMethod": 1,
"primaryPort": 1,
"numMotorDrivers": 0,
"motorDrivers": [
"t": "None",
"s": "",
"invertEnable": "0",
"invertDirection": "0",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"invertEndstop": "0",
"minEndstop": "1",
"endstopPullup": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"t": "None",
"s": "",
"stepsPerMM": 100,
"speed": 10,
"dirPin": -1,
"stepPin": -1,
"enablePin": -1,
"endstopPin": -1,
"minEndstop": "1",
"maxDistance": 20
"manualConfig": "",
"zHomeMinTemperature": 0,
"zHomeXPos": 300,
"zHomeYPos": 300,
"zHomeHeatHeight": 20,
"zHomeHeatAll": "0",
"zProbeZOffsetMode": 0,
"zProbeZOffset": 0,
"zProbeDelay": 0,
"uiBedCoating": "0",
"langEN": "1",
"langDE": "0",
"langNL": "0",
"langPT": "0",
"langIT": "0",
"langES": "0",
"langFI": "0",
"langSE": "0",
"langFR": "0",
"langCZ": "0",
"langPL": "0",
"langTR": "0",
"accelerationFactorTop": 100,
"bendingCorrectionA": 0,
"bendingCorrectionB": 0,
"bendingCorrectionC": 0,
"supportLaser": "0",
"laserPin": -1,
"laserOnHigh": "1",
"laserWarmupTime": 0,
"defaultPrinterMode": 0,
"laserPwmMax": 255,
"laserWatt": 2,
"supportCNC": "0",
"cncWaitOnEnable": 300,
"cncWaitOnDisable": 0,
"cncEnablePin": -1,
"cncEnableWith": "1",
"cncDirectionPin": -1,
"cncDirectionCW": "1",
"cncPwmMax": 255,
"cncRpmMax": 8000,
"cncSafeZ": 150,
"startupGCode": "M42 P67 S0\\n M42 P68 S255\\n M42 P69 S255",
"jsonOutput": "0",
"bedLevelingMethod": 1,
"bedCorrectionMethod": 1,
"bedLevelingGridSize": 6,
"bedLevelingRepetitions": 5,
"bedMotor1X": -148.5,
"bedMotor1Y": 320.5,
"bedMotor2X": 789.5,
"bedMotor2Y": 77.7,
"bedMotor3X": 789.5,
"bedMotor3Y": 563.3,
"zProbeRequiresHeating": "0",
"zProbeMinTemperature": 150,
"adcKeypadPin": -1,
"sharedExtruderHeater": "0",
"extruderSwitchXYSpeed": 100,
"dualXAxis": "0",
"boardFanSpeed": 255,
"keepAliveInterval": 2000,
"moveXWhenHomed": "0",
"moveYWhenHomed": "0",
"moveZWhenHomed": "0",
"preheatTime": 30000,
"multiZEndstopHoming": "0",
"z2MinMaxPin": -1,
"z2MinMaxEndstop": 0,
"extruderIsZProbe": "0",
"boardFanMinSpeed": 0,
"doorPin": -1,
"doorEndstop": 1,
"zhomePreRaise": 2,
"zhomePreRaiseDistance": 6,
"dualXResolution": "0",
"x2axisStepsPerMM": 100,
"coolerPWMSpeed": 0,
"maxFanPWM": 255,
"raiseZOnToolchange": 0,
"distortionLimitTo": 2,
"automaticPowerup": 0,
"hasTMC2130": "0",
"TMC2130Sensorless": "0",
"TMC2130Steathchop": "1",
"TMC2130Interpolate256": "1",
"TMC2130StallguardSensitivity": 0,
"TMC2130PWMAmpl": 255,
"TMC2130PWMGrad": 1,
"TMC2130PWMAutoscale": "1",
"TMC2130PWMFreq": 2,
"TMC2130CSX": -1,
"TMC2130CSY": -1,
"TMC2130CSZ": -1,
"TMC2130CSE0": -1,
"TMC2130CSE1": -1,
"TMC2130CSE2": -1,
"TMC2130CurrentX": 1000,
"TMC2130CurrentY": 1000,
"TMC2130CurrentZ": 1000,
"TMC2130CurrentE0": 1000,
"TMC2130CurrentE1": 1000,
"TMC2130CurrentE2": 1000,
"TMC2130CoolstepTresholdX": 300,
"TMC2130CoolstepTresholdY": 300,
"TMC2130CoolstepTresholdZ": 300,
"microstepX": 16,
"microstepY": 16,
"microstepZ": 16,
"microstepE0": 16,
"microstepE1": 16,
"microstepE2": 16,
"parkPosX": 0,
"parkPosY": 0,
"parkPosZ": 10,
"hasMAX6675": false,
"hasMAX31855": false,
"hasGeneric1": false,
"hasGeneric2": false,
"hasGeneric3": false,
"hasUser0": false,
"hasUser1": false,
"hasUser2": false,
"numExtruder": 2,
"version": 100.2,
"primaryPortName": "Serial"
Pins.h
// RADDS Board
// http://www.dr-henschke.de/RADDS_due.html
#if MOTHERBOARD == 402
#ifndef __SAM3X8E__
#error Oops! Make sure you have 'Arduino Due' selected from the 'Tools -> Boards' menu.
#endif
#define KNOWN_BOARD
#define CPU_ARCH ARCH_ARM
* Arduino Due Pin Assignments
#define ORIG_X_STEP_PIN 24
#define ORIG_X_DIR_PIN 23
#define ORIG_X_MIN_PIN 28
#define ORIG_X_MAX_PIN 34
#define ORIG_X_ENABLE_PIN 26
#define ORIG_Y_STEP_PIN 17
#define ORIG_Y_DIR_PIN 16
#define ORIG_Y_MIN_PIN 30
#define ORIG_Y_MAX_PIN 36
#define ORIG_Y_ENABLE_PIN 22
#define ORIG_Z_STEP_PIN 2
#define ORIG_Z_DIR_PIN 3
#define ORIG_Z_MIN_PIN 32
#define ORIG_Z_MAX_PIN 38
#define ORIG_Z_ENABLE_PIN 15
// Note that on the Due pin A0 on the board is channel 2 on the ARM chip
#define HEATER_0_PIN 13
// Due analog pin #54
#define TEMP_0_PIN 7
#define HEATER_1_PIN 7
#define TEMP_1_PIN 3
// Due analog pin #58
#define HEATER_2_PIN 12
// Due analog pin #55
#define TEMP_2_PIN 6
#define HEATER_3_PIN 11
// Due analog pin #56
#define TEMP_3_PIN 5
// Due analog pin #57
#define TEMP_4_PIN 4
// Due analog pin #59 = A5 -> AD 2
#define THERMOCOUPLE_0_PIN 2
// There are no more analog pins freely available.
// You can use direction and enable pin from extruder 0 socket as they are also
// analog pins. Then you need to move the stepper driver to a different socket.
// Direction pin of extruder 0
#define THERMOCOUPLE_1_PIN 1
// Step pin of extruder 0
#define THERMOCOUPLE_2_PIN 0
// Enable pin of extruder 0
#define THERMOCOUPLE_3_PIN 10
#define ORIG_E0_STEP_PIN 61
#define ORIG_E0_DIR_PIN 60
#define ORIG_E0_ENABLE_PIN 62
#define ORIG_E1_STEP_PIN 64
#define ORIG_E1_DIR_PIN 63
#define ORIG_E1_ENABLE_PIN 65
#define ORIG_E2_STEP_PIN 51
#define ORIG_E2_DIR_PIN 53
#define ORIG_E2_ENABLE_
#ifndef __SAM3X8E__
#endif
#define KNOWN_BOARD
Have no bltouch but M340 is servo so pin 5 I think is correct for servo input plus z min for z probe input. you should then home to z max best.
