Incorrect x,y coordinates in g-code
in Bug Reports
So when I use Repetier and slic3r separate I have no issue but when I use slic3r in Repetier it gives incorrect x,y coordinate. The coordinates are correct in printing an object but are out side the scope of my print area I.e. Min coordantes for x is 239.00 not 0 and max for x is 339.00 not 200 from what I can tell all my setting are correct and work fine when not using slic3r with repetier only when I use it together I have the issue.
