Bed levelling
Goodmorning everyone. I installed a bltouch for bed levelling. with the first manual tests everything moves correctly. But now I was looking for a manual on the internet with the procedures to carry out the bed levelling ... with google I did not find much ... or rather ... many pages but with nothing clear. can anyone suggest a link with the bed-lifting procedure?
You set the 3 points according to the selected leveling method in configuration (there is a picture for it). Make sure they are with active offset of z probe reachable. Go to bed center with z = z rpobe bed distance and run G32 S2. It will measure and store result in eeprom. From there on correction is active. It will also measure distance to z max to adjust z length. If it does not match afterwards the z probe height was wrong. Correct it by what you needed to change z length for a good print.
why is the height of z always 0.003?
but it already correct?
this is my G33 L0 after calibration ... where am i wrong?
