Homing offset and no LCD display of zMin trigger
Running repetier firmware 1.0.2 on a Mega with RAMPS1.4 and a RepRap discount RAMBO display
Printer is a home made HEVO with optical min/max endstops on X and Y and an inductive sensor for zmin (no max endstop on z)
homing order is x,y,preheat,z
I also have the z-probing enabled with a 5x5 grid
Activating the home completes the x and y but as it does the z it shifts the y to -5 (x stays at 0)
I cannot see *anywhere* in the config that this is set and I don't understand why this is happeneing
Further, the z can home successfully at y=-5 as my bed is big enough and I see it retract and retry as expected when the led on the magnetic sensor illuminates
...but the LCD display icon (the empty/filled in square) does not replicate the state of the zmin whilst homeing or if activated manually at any other time say with the use of a screwdriver tip
Any ideas on what is happening here?
  • I assume you have z min endstop and z probe set to same pin?
    Does M119 show z min triggered when it is trigegred?
    Position for homing z is set in configuration, To this the z probe offset is added but that should not be displayed. So I think you have set zhoming position to 0/-5
  • This is very strange, M119 shows that zMin is always L but the probe switches correctly
    The pin setting appears to be the same in the web config but in the generated configuration.h there is no zMinPin defined!
    it contains:
    (which I guess why the probing reacts)
    but no #define for the zMinPin !
    in the configuration string section:
        "xMinPin": "ORIG_X_MIN_PIN",
        "yMinPin": "ORIG_Y_MIN_PIN",
        "zMinPin": "ORIG_Z_MIN_PIN",
        "xMaxPin": "ORIG_X_MAX_PIN",
        "yMaxPin": "ORIG_Y_MAX_PIN",
        "zMaxPin": -1,
        "x2MinPin": -1,
        "y2MinPin": -1,
        "x2MaxPin": -1,
        "y2MaxPin": -1,
    ...there is again no mention of zMinPin
    However, my ZHOME_X_POS and Z_HOME_Y_POS are both set to 999999
    Let me explain *why*
    in the configurator it says "[mm / 999999 = do not change]"
    I read this as meaning "the units in this section are mm and IF the config boxes have 999999 in them then do not change this value or bad things will happen"
    ....so I left them as 999999 !
    Re-reading it and thinking about it I believe this means "the units in this section are mm and if you put 999999 INTO them then whatever x and y co-ordinates the head is at when it does the home, that is what is used for the z home position"
    My interpretation aside, perhaps they should be 0,0 but 999999 is properly defined as IGNORE_COORDINATE therefore I would expect it to correlate and not move
    I have also noticed I don't have Z_PROBE_DISABLE_HEATERS checked but I do have ZHOME_MIN_TEMPERATURE set to 0
    My gut feeling is that the permutation of settings I have is an edge case for the configurator and it misses the zMinPin setting
    The use of 999999 and the conclusion that the X and Y should not change and they are already at 0,0 is a leap of faith !
    I have attached 2 screenshots of the configurator; endstops and z-probe along with my configuration.h file for consideration on these findings
    Thank you in advance for your help
        MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
        along with Repetier-Firmware.  If not, see <http://www.gnu.org/licenses/>.
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
       This file is optimized for version 1.0.2
       as you expect.
    #define NUM_EXTRUDER 1
    #define MOTHERBOARD 33
    #include "pins.h"
    #undef FAN_PIN
    #define FAN_PIN 11
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define BOARD_FAN_MIN_SPEED 0
    #define FAN_THERMO_PIN -1
    #undef Z_MAX_PIN
    #define Z_MAX_PIN -1
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 1
    #define XAXIS_STEPS_PER_MM 320
    #define YAXIS_STEPS_PER_MM 320
    #define ZAXIS_STEPS_PER_MM 800
    #define EXTRUDER_FAN_COOL_TEMP 40
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 1000
    #define EXT0_TEMPSENSOR_TYPE 14
    #define EXT0_HEATER_PIN HEATER_1_PIN
    #define EXT0_INVERSE 0
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 60
    #define EXT0_MAX_START_FEEDRATE 3
    #define EXT0_HEAT_MANAGER 1
    #define EXT0_PREHEAT_TEMP 190
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_PGAIN_OR_DEAD_TIME 7.08
    #define EXT0_PID_I 0.65
    #define EXT0_PID_D 19.26
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_EXTRUDER_COOLER_PIN 6
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define JAM_METHOD 1
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define COOLER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_SENSOR_TYPE 14
    #define HEATED_BED_HEATER_PIN HEATER_2_PIN
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   98.04
    #define HEATED_BED_PID_IGAIN   7.55
    #define HEATED_BED_PID_DGAIN 318.25
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 275
    #define MILLISECONDS_PREHEAT_TIME 5000
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    #define LASER_WARMUP_TIME 0
    #define LASER_PWM_MAX 255
    #define LASER_WATT 2
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define CNC_PWM_MAX 255
    #define CNC_RPM_MAX 8000
    #define CNC_SAFE_Z 150
    #define ENDSTOP_PULLUP_X_MIN false
    #define ENDSTOP_PULLUP_Y_MIN false
    #define ENDSTOP_PULLUP_X_MAX false
    #define ENDSTOP_PULLUP_Y_MAX false
    #define X2_MIN_PIN -1
    #define X2_MAX_PIN -1
    #define Y2_MIN_PIN -1
    #define Y2_MAX_PIN -1
    #define Z2_MINMAX_PIN -1
    #define DOOR_PIN -1
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 0
    #define ENDSTOP_X_BACK_MOVE 5
    #define ENDSTOP_Y_BACK_MOVE 5
    #define ENDSTOP_Z_BACK_MOVE 2
    #define ENDSTOP_X_RETEST_REDUCTION_FACTOR 10
    #define ENDSTOP_Y_RETEST_REDUCTION_FACTOR 10
    #define ENDSTOP_Z_RETEST_REDUCTION_FACTOR 5
    #define ENDSTOP_X_BACK_ON_HOME 0
    #define ENDSTOP_Y_BACK_ON_HOME 0
    #define MOVE_X_WHEN_HOMED 0
    #define MOVE_Y_WHEN_HOMED 0
    #define MOVE_Z_WHEN_HOMED 0
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define INVERT_X_DIR 0
    #define INVERT_X2_DIR 0
    #define INVERT_Y_DIR 0
    #define INVERT_Y2_DIR 0
    #define INVERT_Z_DIR 0
    #define INVERT_Z2_DIR 0
    #define INVERT_Z3_DIR 0
    #define INVERT_Z4_DIR 0
    #define X_HOME_DIR -1
    #define Y_HOME_DIR -1
    #define Z_HOME_DIR -1
    #define X_MAX_LENGTH 300
    #define Y_MAX_LENGTH 300
    #define Z_MAX_LENGTH 300
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define PARK_POSITION_X 0
    #define PARK_POSITION_Y 10
    #define DISTORTION_LIMIT_TO 2
    #define DISTORTION_XMIN 0
    #define DISTORTION_YMIN 0
    #define DISTORTION_XMAX 0
    #define DISTORTION_YMAX 0
    // ##                           Movement settings                                          ##
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 500
    #define MAX_FEEDRATE_Y 500
    #define MAX_FEEDRATE_Z 8
    #define HOMING_FEEDRATE_X 60
    #define HOMING_FEEDRATE_Y 60
    #define HOMING_FEEDRATE_Z 5
    #define HOMING_ORDER HOME_ORDER_XYTZ
    #define ZHOME_PRE_RAISE 2
    #define ZHOME_PRE_RAISE_DISTANCE 2
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 3
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 1
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 2000
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 2000
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 3000
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 3000
    #define MAX_JERK 15
    #define MAX_ZJERK 0.3
    #define PRINTLINE_CACHE_SIZE 32
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define DUAL_X_RESOLUTION 0
    #define X2_STEP_PIN   ORIG_E1_STEP_PIN
    #define X2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define Z4_STEP_PIN   ORIG_E3_STEP_PIN
    #define Z4_DIR_PIN    ORIG_E3_DIR_PIN
    #define USE_ADVANCE 0
    #define BAUDRATE 250000
    #define ENABLE_POWER_ON_STARTUP 0
    #define POWER_INVERTING 0
    #define AUTOMATIC_POWERUP 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 2
    #undef PS_ON_PIN
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define UI_SERVO_CONTROL 0
    #define FAN_KICKSTART_TIME  500
    #define MAX_FAN_PWM 255
            #define FEATURE_WATCHDOG 1
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 1
    #define EXTRUDER_IS_Z_PROBE 0
    #define Z_PROBE_BED_DISTANCE 1
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 0
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET 0
    #define Z_PROBE_SPEED 2
    #define Z_PROBE_XY_SPEED 200
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_HEIGHT 0.7
    #define Z_PROBE_DELAY 0
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 25
    #define Z_PROBE_Y1 25
    #define Z_PROBE_X2 275
    #define Z_PROBE_Y2 25
    #define Z_PROBE_X3 25
    #define Z_PROBE_Y3 275
    #define BED_LEVELING_METHOD 1
    #define BED_LEVELING_GRID_SIZE 6
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 1
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #define SD_RUN_ON_STOP ""
    #define SD_STOP_HEATER_AND_MOTORS_ON_STOP 0
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 11
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define UI_PRINTER_NAME "HEVO3003.a2"
    #define UI_PRINTER_COMPANY "Havenview"
    #define UI_AUTORETURN_TO_MENU_AFTER 300000
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 2
    #define UI_REVERSE_ENCODER 1
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 0
    #define CASE_LIGHTS_PIN 57
    #define CASE_LIGHT_DEFAULT_ON 0
    #define UI_START_SCREEN_DELAY 3000
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   260
    #define NUM_MOTOR_DRIVERS 0
    // HEVO 3003.a.1
    // Changes:
    // MOVE_CACHE_SIZE up to 32
    // travel accn to 3000 and print accn to 2000
    // homing order to Z up,x,y,preheat,Z
    // extruder start speed down to 3 and max speed up to 60
    // case light to D57 (AKA A3 on AUX1)
    // HEVO3003.a2
    // Changes:
    // release name convention
    // home order to x,y,preheat,z
    // level grid to 25,25:275,275
    // grid points to 6x6
        "editMode": 2,
        "processor": 0,
        "baudrate": 250000,
        "bluetoothSerial": -1,
        "bluetoothBaudrate": 115200,
        "xStepsPerMM": 320,
        "yStepsPerMM": 320,
        "zStepsPerMM": 800,
        "xInvert": "0",
        "x2Invert": 0,
        "xInvertEnable": 0,
        "eepromMode": 2,
        "yInvert": 0,
        "y2Invert": 0,
        "yInvertEnable": 0,
        "zInvert": "0",
        "z2Invert": 0,
        "z3Invert": 0,
        "z4Invert": 0,
        "zInvertEnable": 0,
        "extruder": [
                "id": 0,
                "heatManager": 1,
                "pidDriveMin": 40,
                "pidDriveMax": 230,
                "pidMax": 255,
                "sensorType": 14,
                "sensorPin": "TEMP_0_PIN",
                "heaterPin": "HEATER_1_PIN",
                "maxFeedrate": 60,
                "startFeedrate": 3,
                "invert": "0",
                "invertEnable": "0",
                "acceleration": 5000,
                "watchPeriod": 1,
                "pidP": 7.08,
                "pidI": 0.65,
                "pidD": 19.26,
                "advanceK": 0,
                "advanceL": 0,
                "waitRetractTemp": 150,
                "waitRetractUnits": 0,
                "waitRetract": 0,
                "stepsPerMM": 1000,
                "coolerPin": 6,
                "coolerSpeed": 255,
                "selectCommands": "",
                "deselectCommands": "",
                "xOffset": 0,
                "yOffset": 0,
                "zOffset": 0,
                "xOffsetSteps": 0,
                "yOffsetSteps": 0,
                "zOffsetSteps": 0,
                "stepper": {
                    "name": "Extruder 0",
                    "step": "ORIG_E0_STEP_PIN",
                    "dir": "ORIG_E0_DIR_PIN",
                "advanceBacklashSteps": 0,
                "decoupleTestPeriod": 12,
                "jamPin": -1,
                "jamPullup": "0",
                "mirror": "0",
                "invert2": "0",
                "stepper2": {
                "preheat": 190
        "uiLanguage": 0,
        "uiController": 0,
        "xMinEndstop": 4,
        "yMinEndstop": 4,
        "zMinEndstop": 3,
        "xMaxEndstop": 4,
        "yMaxEndstop": 4,
        "zMaxEndstop": 0,
        "x2MinEndstop": 0,
        "y2MinEndstop": 0,
        "x2MaxEndstop": 0,
        "y2MaxEndstop": 0,
        "motherboard": 33,
        "driveSystem": 1,
        "xMaxSpeed": 500,
        "xHomingSpeed": 60,
        "xTravelAcceleration": 3000,
        "xPrintAcceleration": 2000,
        "yMaxSpeed": 500,
        "yHomingSpeed": 60,
        "yTravelAcceleration": 3000,
        "yPrintAcceleration": 2000,
        "zMaxSpeed": 8,
        "zHomingSpeed": 5,
        "zTravelAcceleration": 100,
        "zPrintAcceleration": 100,
        "xMotor": {
            "name": "X motor",
            "step": "ORIG_X_STEP_PIN",
            "dir": "ORIG_X_DIR_PIN",
            "enable": "ORIG_X_ENABLE_PIN"
        "yMotor": {
            "name": "Y motor",
            "step": "ORIG_Y_STEP_PIN",
            "dir": "ORIG_Y_DIR_PIN",
            "enable": "ORIG_Y_ENABLE_PIN"
        "zMotor": {
            "name": "Z motor",
            "step": "ORIG_Z_STEP_PIN",
            "dir": "ORIG_Z_DIR_PIN",
            "enable": "ORIG_Z_ENABLE_PIN"
        "enableBacklash": "0",
        "backlashX": 0,
        "backlashY": 0,
        "backlashZ": 0,
        "stepperInactiveTime": 360,
        "maxInactiveTime": 0,
        "xMinPos": 0,
        "yMinPos": 0,
        "zMinPos": 0,
        "xLength": 300,
        "yLength": 300,
        "zLength": 300,
        "alwaysCheckEndstops": "0",
        "disableX": "0",
        "disableY": "0",
        "disableZ": "0",
        "disableE": "0",
        "xHomeDir": "-1",
        "yHomeDir": "-1",
        "zHomeDir": "-1",
        "xEndstopBack": 0,
        "yEndstopBack": 0,
        "zEndstopBack": 0,
        "deltaDiagonalRod": 445,
        "deltaAlphaA": 210,
        "deltaAlphaB": 330,
        "deltaAlphaC": 90,
        "deltaDiagonalCorrA": 0,
        "deltaDiagonalCorrB": 0,
        "deltaDiagonalCorrC": 0,
        "deltaMaxRadius": 150,
        "deltaRadiusCorrA": 0,
        "deltaRadiusCorrB": 0,
        "deltaRadiusCorrC": 0,
        "deltaXOffsetSteps": 0,
        "deltaYOffsetSteps": 0,
        "deltaZOffsetSteps": 0,
        "deltaSegmentsPerLine": 24,
        "stepperHighDelay": 1,
        "directionDelay": 0,
        "allowQuadstepping": "1",
        "doubleStepDelay": 0,
        "maxJerk": 15,
        "maxZJerk": 0.3,
        "moveCacheSize": 32,
        "moveCacheLow": 10,
        "lowTicksPerMove": 250000,
        "enablePowerOnStartup": "0",
        "echoOnExecute": "1",
        "sendWaits": "1",
        "ackWithLineNumber": "1",
        "killMethod": 1,
        "useAdvance": "0",
        "useQuadraticAdvance": "0",
        "powerInverting": 0,
        "mirrorX": 0,
        "mirrorXMotor": {
            "name": "Extruder 1",
            "step": "ORIG_E1_STEP_PIN",
            "dir": "ORIG_E1_DIR_PIN",
        "mirrorY": 0,
        "mirrorYMotor": {
        "mirrorZ": "0",
        "mirrorZMotor": {
        "mirrorZ3": "0",
        "mirrorZ3Motor": {
            "name": "Extruder 2",
            "step": "ORIG_E2_STEP_PIN",
            "dir": "ORIG_E2_DIR_PIN",
        "mirrorZ4": "0",
        "mirrorZ4Motor": {
            "name": "Extruder 3",
            "step": "ORIG_E3_STEP_PIN",
            "dir": "ORIG_E3_DIR_PIN",
        "dittoPrinting": "0",
        "featureServos": "0",
        "servo0Pin": 11,
        "servo1Pin": -1,
        "servo2Pin": -1,
        "servo3Pin": -1,
        "featureWatchdog": "1",
        "hasHeatedBed": "1",
        "enableZProbing": "1",
        "extrudeMaxLength": 160,
        "homeOrder": "HOME_ORDER_XYTZ",
        "featureController": 11,
        "uiPrinterName": "HEVO3003.a2",
        "uiPrinterCompany": "Havenview",
        "uiPagesDuration": 4000,
        "uiHeadline": "",
        "uiDisablePageswitch": "1",
        "uiAutoReturnAfter": 300000,
        "featureKeys": "0",
        "uiEncoderSpeed": 2,
        "uiReverseEncoder": "1",
        "uiKeyBouncetime": 10,
        "uiKeyFirstRepeat": 500,
        "uiKeyReduceRepeat": 50,
        "uiKeyMinRepeat": 50,
        "featureBeeper": "0",
        "uiMinHeatedBed": 30,
        "uiMaxHeatedBed": 120,
        "uiMinEtxruderTemp": 170,
        "uiMaxExtruderTemp": 260,
        "uiExtruderFeedrate": 2,
        "maxBedTemperature": 120,
        "bedSensorType": 14,
        "bedSensorPin": "TEMP_1_PIN",
        "bedHeaterPin": "HEATER_2_PIN",
        "bedHeatManager": 1,
        "bedPreheat": 55,
        "bedUpdateInterval": 5000,
        "bedPidDriveMin": 80,
        "bedPidDriveMax": 255,
        "bedPidP": 98.04,
        "bedPidI": 7.55,
        "bedPidD": 318.25,
        "bedPidMax": 255,
        "bedDecoupleTestPeriod": 300,
        "caseLightPin": 57,
        "caseLightDefaultOn": "0",
        "bedSkipIfWithin": 3,
        "gen1T0": 25,
        "gen1R0": 100000,
        "gen1Beta": 4036,
        "gen1MinTemp": -20,
        "gen1MaxTemp": 300,
        "gen1R1": 0,
        "gen1R2": 4700,
        "gen2T0": 25,
        "gen2R0": 100000,
        "gen2Beta": 4036,
        "gen2MinTemp": -20,
        "gen2MaxTemp": 300,
        "gen2R1": 0,
        "gen2R2": 4700,
        "gen3T0": 25,
        "gen3R0": 100000,
        "gen3Beta": 4036,
        "gen3MinTemp": -20,
        "gen3MaxTemp": 300,
        "gen3R1": 0,
        "gen3R2": 4700,
        "userTable0": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable1": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable2": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "tempHysteresis": 0,
        "pidControlRange": 20,
        "skipM109Within": 2,
        "extruderFanCoolTemp": 40,
        "minTemp": 150,
        "maxTemp": 275,
        "minDefectTemp": -10,
        "maxDefectTemp": 290,
        "arcSupport": "1",
        "forceChecksum": "0",
        "sdExtendedDir": "1",
        "featureFanControl": "1",
        "fanPin": 11,
        "featureFan2Control": "0",
        "fan2Pin": "ORIG_FAN2_PIN",
        "fanThermoPin": -1,
        "fanThermoMinPWM": 128,
        "fanThermoMaxPWM": 255,
        "fanThermoMinTemp": 45,
        "fanThermoMaxTemp": 60,
        "fanThermoThermistorPin": -1,
        "fanThermoThermistorType": 1,
        "scalePidToMax": 0,
        "zProbePin": "ORIG_Z_MIN_PIN",
        "zProbeBedDistance": 1,
        "zProbeDisableHeaters": "0",
        "zProbePullup": "0",
        "zProbeOnHigh": "0",
        "zProbeXOffset": 0,
        "zProbeYOffset": 0,
        "zProbeWaitBeforeTest": "0",
        "zProbeSpeed": 2,
        "zProbeXYSpeed": 200,
        "zProbeHeight": 0.7,
        "zProbeStartScript": "",
        "zProbeFinishedScript": "",
        "featureAutolevel": "1",
        "zProbeX1": 25,
        "zProbeY1": 25,
        "zProbeX2": 275,
        "zProbeY2": 25,
        "zProbeX3": 25,
        "zProbeY3": 275,
        "zProbeSwitchingDistance": 1,
        "zProbeRepetitions": 1,
        "zProbeEveryPoint": "",
        "sdSupport": "1",
        "sdCardDetectPin": -1,
        "sdCardDetectInverted": "0",
        "uiStartScreenDelay": 3000,
        "xEndstopBackMove": 5,
        "yEndstopBackMove": 5,
        "zEndstopBackMove": 2,
        "xEndstopRetestFactor": 10,
        "yEndstopRetestFactor": 10,
        "zEndstopRetestFactor": 5,
        "zMaxPin": -1,
        "x2MinPin": -1,
        "y2MinPin": -1,
        "x2MaxPin": -1,
        "y2MaxPin": -1,
        "deltaHomeOnPower": "0",
        "fanBoardPin": -1,
        "heaterPWMSpeed": 0,
        "featureBabystepping": "1",
        "babystepMultiplicator": 1,
        "pdmForHeater": "0",
        "pdmForCooler": "0",
        "psOn": "ORIG_PS_ON_PIN",
        "mixingExtruder": "0",
        "featureAxisComp": "0",
        "axisCompTanXY": 0,
        "axisCompTanXZ": 0,
        "axisCompTanYZ": 0,
        "retractOnPause": 2,
        "pauseStartCommands": "",
        "pauseEndCommands": "",
        "distortionCorrection": "0",
        "distortionCorrectionR": 100,
        "distortionPermanent": "1",
        "distortionEndDegrade": 1,
        "distortionXMin": 0,
        "distortionXMax": 0,
        "distortionYMin": 0,
        "distortionYMax": 0,
        "sdRunOnStop": "",
        "sdStopHeaterMotorsOnStop": "0",
        "featureRetraction": "1",
        "autoretractEnabled": "0",
        "retractionLength": 3,
        "retractionLongLength": 13,
        "retractionSpeed": 40,
        "retractionZLift": 0,
        "retractionUndoSpeed": 20,
        "filamentChangeXPos": 0,
        "filamentChangeYPos": 0,
        "filamentChangeZAdd": 2,
        "filamentChangeRehome": 1,
        "fanKickstart": 500,
        "servo0StartPos": -1,
        "servo1StartPos": -1,
        "servo2StartPos": -1,
        "servo3StartPos": -1,
        "uiDynamicEncoderSpeed": "1",
        "uiServoControl": 0,
        "killIfSensorDefect": "0",
        "jamSteps": 220,
        "jamSlowdownSteps": 320,
        "jamSlowdownTo": 70,
        "jamErrorSteps": 500,
        "jamMinSteps": 10,
        "jamAction": 1,
        "jamMethod": 1,
        "primaryPort": 0,
        "numMotorDrivers": 0,
        "motorDrivers": [
                "t": "None",
                "s": "",
                "invertDirection": "0",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "invertEndstop": "0",
                "minEndstop": "1",
                "endstopPullup": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
        "manualConfig": "\/\/ HEVO 3003.a.1\n\n\/\/ Changes:\n\/\/ MOVE_CACHE_SIZE up to 32\n\/\/ travel accn to 3000 and print accn to 2000\n\/\/ homing order to Z up,x,y,preheat,Z\n\/\/ extruder start speed down to 3 and max speed up to 60\n\/\/ case light to D57 (AKA A3 on AUX1)\n\n\/\/ HEVO3003.a2\n\/\/ Changes:\n\/\/ release name convention\n\/\/ home order to x,y,preheat,z\n\/\/ level grid to 25,25:275,275\n\/\/ grid points to 6x6",
        "zHomeMinTemperature": 0,
        "zHomeXPos": 999999,
        "zHomeYPos": 999999,
        "zHomeHeatHeight": 3,
        "zHomeHeatAll": "1",
        "zProbeZOffsetMode": 0,
        "zProbeZOffset": 0,
        "zProbeDelay": 0,
        "uiBedCoating": "1",
        "langEN": "1",
        "langDE": "0",
        "langNL": "0",
        "langPT": "0",
        "langIT": "0",
        "langES": "0",
        "langFI": "0",
        "langSE": "0",
        "langFR": "0",
        "langCZ": "0",
        "langPL": "0",
        "langTR": "0",
        "accelerationFactorTop": 100,
        "bendingCorrectionA": 0,
        "bendingCorrectionB": 0,
        "bendingCorrectionC": 0,
        "supportLaser": "0",
        "laserPin": -1,
        "laserOnHigh": "1",
        "laserWarmupTime": 0,
        "defaultPrinterMode": 0,
        "laserPwmMax": 255,
        "laserWatt": 2,
        "supportCNC": "0",
        "cncWaitOnEnable": 300,
        "cncWaitOnDisable": 0,
        "cncEnablePin": -1,
        "cncEnableWith": "1",
        "cncDirectionPin": -1,
        "cncDirectionCW": "1",
        "cncPwmMax": 255,
        "cncRpmMax": 8000,
        "cncSafeZ": 150,
        "startupGCode": "",
        "jsonOutput": "0",
        "bedLevelingMethod": 1,
        "bedCorrectionMethod": 0,
        "bedLevelingGridSize": 6,
        "bedLevelingRepetitions": 5,
        "bedMotor1X": 0,
        "bedMotor1Y": 0,
        "bedMotor2X": 200,
        "bedMotor2Y": 0,
        "bedMotor3X": 100,
        "bedMotor3Y": 200,
        "zProbeRequiresHeating": "0",
        "zProbeMinTemperature": 150,
        "adcKeypadPin": -1,
        "sharedExtruderHeater": "0",
        "extruderSwitchXYSpeed": 100,
        "dualXAxis": "0",
        "boardFanSpeed": 255,
        "keepAliveInterval": 2000,
        "moveXWhenHomed": "0",
        "moveYWhenHomed": "0",
        "moveZWhenHomed": "0",
        "preheatTime": 5000,
        "multiZEndstopHoming": "0",
        "z2MinMaxPin": -1,
        "z2MinMaxEndstop": 0,
        "extruderIsZProbe": "0",
        "boardFanMinSpeed": 0,
        "doorPin": -1,
        "doorEndstop": 0,
        "zhomePreRaise": 2,
        "zhomePreRaiseDistance": 2,
        "dualXResolution": "0",
        "x2axisStepsPerMM": 100,
        "coolerPWMSpeed": 0,
        "maxFanPWM": 255,
        "raiseZOnToolchange": 0,
        "distortionLimitTo": 2,
        "automaticPowerup": 0,
        "hasTMC2130": "0",
        "TMC2130Sensorless": "0",
        "TMC2130Steathchop": "1",
        "TMC2130Interpolate256": "1",
        "TMC2130StallguardSensitivity": 0,
        "TMC2130PWMAmpl": 255,
        "TMC2130PWMGrad": 1,
        "TMC2130PWMAutoscale": "1",
        "TMC2130PWMFreq": 2,
        "TMC2130CSX": -1,
        "TMC2130CSY": -1,
        "TMC2130CSZ": -1,
        "TMC2130CSE0": -1,
        "TMC2130CSE1": -1,
        "TMC2130CSE2": -1,
        "TMC2130CurrentX": 1000,
        "TMC2130CurrentY": 1000,
        "TMC2130CurrentZ": 1000,
        "TMC2130CurrentE0": 1000,
        "TMC2130CurrentE1": 1000,
        "TMC2130CurrentE2": 1000,
        "TMC2130CoolstepTresholdX": 300,
        "TMC2130CoolstepTresholdY": 300,
        "TMC2130CoolstepTresholdZ": 300,
        "microstepX": 16,
        "microstepY": 16,
        "microstepZ": 16,
        "microstepE0": 16,
        "microstepE1": 16,
        "microstepE2": 16,
        "parkPosX": 0,
        "parkPosY": 0,
        "parkPosZ": 10,
        "uiAnimation": "0",
        "uiPresetBedTempPLA": 60,
        "uiPresetBedABS": 110,
        "uiPresetExtruderPLA": 190,
        "uiPresetExtruderABS": 240,
        "hasMAX6675": false,
        "hasMAX31855": false,
        "hasGeneric1": false,
        "hasGeneric2": false,
        "hasGeneric3": false,
        "hasUser0": false,
        "hasUser1": false,
        "hasUser2": false,
        "numExtruder": 1,
        "version": 100.2,
        "primaryPortName": ""
  • You should set the  XY HOMING POS FOR Z (ZHOME_X_POS/ZHOME_Y_POS) to the actual bed location that yoou want to home Z at eg.  100 100
    If left at 999999 999999  it wil try to home Z at the current xy location
  • edited August 2018
    I agree but that is not what I am seeing - It pulls the head forward to y=-5
    note that if the x and y are undetermined (say after turning the steppers off and the location indicates an assumed value then ???), doing a home z will home x,y (to 0,0) then z, but with the y=-5 offset
  • I've just re-checked this and it appears that the y=-5 offset only ever happens if the zhome needs to do an x and y home beforehand because the x and y positions are undetermined (ie when my x,y,z positions on the LCD display flash between assumed value and ?.??)
    If x and y are determined values then the z home does stay static to the current x and y co-ords
  • ...and on re-re-checking the above is only correct when the home issued is a z-only
    sending a G28 always causes the z to home at 0,-5 irrespective of the x and y being undetermined or known
  • Sounds like the Y-5 always happens when Y is homed. You have back on home 5 for x and y but that should not cause this becoming a coordinate. You can try setting this to 6 to verify it does not come from this. It is more likely that you have in eeprom these values as z probe offset.
    Having no entry for Z_MIN_PIN is ok as this is preset with ORIG_Z_MIN_PIN or at least it should be. And being the same you must get same report for z min with M119. In fact if you look into Endstops.cpp in update you see:
    #if FEATURE_Z_PROBE
    #if Z_PROBE_PIN == Z_MIN_PIN && MIN_HARDWARE_ENDSTOP_Z
        if(newRead & ENDSTOP_Z_MIN_ID) // prevent different results causing confusion
            newRead |= ENDSTOP_Z_PROBE_ID;
        if(!Printer::isHoming())
            newRead &= ~ENDSTOP_Z_MIN_ID; // could cause wrong signals depending on probe position
    #else
        if(Z_PROBE_ON_HIGH ? READ(Z_PROBE_PIN) : !READ(Z_PROBE_PIN))
    #endif
    #endif
    You see in case of identical pins it even doe snot test z probe and just copies the z min state to z probe. To verify it is using that code you can add after
    this line
    #error compiles right part.
    Next compilation should fail with the error message. Then you know it uses that case.
  • Thanks for your comments. I have spent the past 2 evenings progressing this
    Having gone through the code, I am concurrent on your description of the default pin settings and now understand how they are set to "ORIG_" values from the start and only moved away from them if subsequently overridden with "user config"
    The probe to y=-5 phenomena is a feature of having the X & Y homing position at 999999 (or what is #defined in the code as IGNORE_COORDINATE) - as soon as I set the X & Y homing positions to 0,0 then the y=-5 offset never happens
    I do not believe I have the probe offset at anything apart from 0,0 as I had problems too with "moved to illegal values" errors if I had the true value of offset in there and I had to set it to 0,0 to make it work
    My next attempt was to put back measured offsets into the probe offset (x=22, y=0) and it started to throw errors in the display about out of bounds moves again. At this point I then had the idea to move the X & Y homing positions to 22,0 and it then worked...but in a strange way. It brings the print head tip (as opposed to the probe centre) down at 22,0 to about z=2mm and at that point it moves the head tip to 0,0 and hence the probe centre to 22,0 for the move to measure the z home position. When its done that and its post probe raise, it zips back to 22,0, probes at that position (ie probe at 44,0) and then moves the tip back to 0,0,0 which is the true home position
    I'm not sure why there is this switch at the final probing move - I would expect it to go straight there and I can't make out the second probe attempt at probe position 44,0 but with those settings I no longer get any out of bounds errors
    Also, with those settings my 6x6 probe grid now works properly. my p1,p2,p3 positions are set at a bounding box of 25,25:275,275 so the 22,0 offset sits sweet withing that and when it does *those* probes the tip>probe values seem to work as you would expect ie the first probe is at tip location 3,25 (ie P1 25,25 less z_probe 22,0). For the first time ever, my bed is properly level !
    Throughout all of this the LCD zmin indication (and corresponding results with M119) the zmin always stays low with the zprobe correctly switching between low (meaning "away from bed") and high (meaning "triggered and close to bed"). My gut feeling is that if I disable the z probing (FEATURE_Z_PROBE) the LCD and M119 indication will show for zmin, but this will be tomorrow as I need some rest now!
  • Further update.
    I have recompiled with FEATURE_Z_PROBE 0 being the only change and the zmin on the LCD display then shows correctly with a filled in square when the probe is triggered and an empty one when it is clear.
    I've tried to decipher how this is achieved  and I believe the state is held in Endstops::zMin() which is #if'd in the header file but I can't work out how the display is achieved. I think you use a placeholder system of %sz but I see no difference in this between FEATURE_Z_PROBE being 1 or 0
    Is there anything else I can try to debug further?
  • Ok, I reread the part I've shown you and the answer was already in that code part:
    #if FEATURE_Z_PROBE
    #else
    #endif
    #endif
    As you see this line is the cause
    it disables z min when z probe triggers and that for a good reason! Z probe triggers before you hit the bed, so if you test endstops and go to Z = 1 and then down to Z=0 it will stop before the bed is hit just because z min is triggered. In fact you have no z min because you have a z probe used for homing. And therefore z min never triggers. It would be more correct to not show it in M119 at all as it never triggers by design.
  • Its taken me a while but I understand this a little more now
    I can appreciate the need to ignore z-min if you are using z-probing
    The discrepancy I can see is in the LCD display output
    The code seems to imply you have a placeholder as I said before (decoded in ui.cpp > UIDisplay::parse)
    You decode to 3 characters with variable names c, c1 and c2
    c looks for the % placeholder
    c1 is the first character of the command
    c2 is the second character of the command
    The parser does a case 's': for c1 at line 1598
    this is the trap for the %s endstops
    it rattles through permutations of c2 that cover xyzminmax endstops and then finally for %sP for the probe
    uimenu.h lists those commands so for example %sX is the x max endstop but interestingly here there seems to be no mention of the %sP
    I think that means that the %sP placeholder is never used in the menu system which is why with z-probing using the z-min pin we never see the z-probe state in the menu display, only ever z-min which is always 'off' because of the need to ignore that in this scenario
    I can't quite get my head around how this is then structured forward to create the menus and show the right item
    Have I interpreted the code correctly so far?
  • Without having read code again I think you are right. In the translations i sthe code for z min endstop whcih is never triggered. That could be rpelaced with the z probe signal in the big case for the case z probe = z min. Then it would at least show z pribe signal also this triggers before z min. But makes more sense then always off. Will check later and modify the code.
