Diamond Mixedcolor Extruders
If i adjust my extruders, they have different Resolution.
For example: Feed 100mm on every extruder.
Result:
EXT1: 100mm
Ext2: 101mm
Ext3: 110mm
Is there any posibility to setup the Resolution for each extruder ?
This setting was gone after i set Mixing Extruder = 1
Thanks for Help
Result:
EXT1: 100mm
Ext2: 101mm
Ext3: 110mm
Thanks for Help
its ok. in configuration.h i still can change the setting. Only on the webpage configuration this setting is gone.
thanks
