Acceleration/Travel acceleraion
As many slicers do not generate G0 moves , Travel acceleration is not used.
So two ways to go, replacing the G1 in fast moves by G0 in Gcode file , whats a ugly mess...
or switching over in Firmware (selected by feedrate).
but cannot find the correct position where to do this.
any suggestions?
  • G0/G1 are identical. Travel acceleration is used when there is no extrusion.
  • ok,thanks (althoug that makes no sense as it doesn´t  match gcode standards)
    not shure if i understood correctly , so how to make a difference in Laser or CNC mode ?
  • In laser mode the difference is that G0 does not enable the laser. Travel acceleration is used if no extrusion happens. Apart from this there is no difference.
