Just upgraded from firmware 0.92.9 to 1.0.2
Hi I have just upgraded to ver 1.0.2 to enable the G33 functionality, I'm using a home built delta with a 560 mm build height, control is arduino due with a fdramps derivative, works fine under 0.92.9 but under 1.0.2 I am finding that the control appears to reset ( spash screen displays and motion stops ) after about 250mm of z movement after I issue a G28 ( home command ), i'm using micro step drives giving 160 steps/mm for each axis, anyone seen this sort of behaviour before? ( the 1.0.2 firmware was built using the config tool and the config file from my 0.92.9 version ), just going to re-flash my original 0.92.9 firmware for now. Happy to try almost anything to get up and running with 1.0.2
In the meantime I'll take a look at the watchdog functionality between 0.92.9 and 1.0.2 to see if anything has changed.
