Firmware 1.0.3Dev does not compile
Just tried Firmware 1.0.3Dev and it does not compile.  Is it possible to specify a particular version other than 0.9.2.x or "whatever the latest version today is"?  I'd like to use 1.0.1 or 1.0.2.  I'm trying to add features on the printer and it would be nice if I could stick to one firmware version during my integration and testing process.
Received the following error:
Arduino: 1.8.5 (Mac OS X), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from sketch/HAL.h:89:0,
                 from sketch/Repetier.h:597,
                 from sketch/HAL.cpp:1:
sketch/HAL.cpp: In function 'void __vector_22()':
fastio.h:29: error: 'DIOHEATER_7_PIN_WPORT' was not declared in this scope
 #define  _WRITE(IO, v)   do { if (v) {DIO ##  IO ## _WPORT |= MASK(DIO ## IO ## _PIN); } else {DIO ##  IO ## _WPORT &= ~MASK(DIO ## IO ## _PIN); }; } while (0)
sketch/fastio.h:48:25: note: in expansion of macro '_WRITE'
 #define  WRITE(IO, v)   _WRITE(IO, v)
sketch/HAL.cpp:830:91: note: in expansion of macro 'WRITE'
         if((pwm_pos_set[PWM_BOARD_FAN] = (pwm_pos[PWM_BOARD_FAN] & COOLER_PWM_MASK)) > 0) WRITE(FAN_BOARD_PIN, 1);
fastio.h:29: error: 'DIOHEATER_7_PIN_PIN' was not declared in this scope
sketch/fastio.h:17:30: note: in definition of macro 'MASK'
  #define  MASK(PIN)    (1 << PIN)
fastio.h:29: error: 'DIOHEATER_6_PIN_WPORT' was not declared in this scope
sketch/HAL.cpp:833:81: note: in expansion of macro 'WRITE'
         if((pwm_pos_set[PWM_FAN1] = (pwm_pos[PWM_FAN1] & COOLER_PWM_MASK)) > 0) WRITE(FAN_PIN, 1);
fastio.h:29: error: 'DIOHEATER_6_PIN_PIN' was not declared in this scope
sketch/HAL.cpp:930:105: note: in expansion of macro 'WRITE'
     if(pwm_pos_set[PWM_BOARD_FAN] == pwm_count_cooler && pwm_pos_set[PWM_BOARD_FAN] != COOLER_PWM_MASK) WRITE(FAN_BOARD_PIN, 0);
sketch/HAL.cpp:938:99: note: in expansion of macro 'WRITE'
         if(pwm_pos_set[PWM_FAN1] == pwm_count_cooler && pwm_pos_set[PWM_FAN1] != COOLER_PWM_MASK) WRITE(FAN_PIN, 0);
sketch/HAL.cpp:944:119: note: in expansion of macro 'WRITE'
         if((MAX_FAN_PWM & COOLER_PWM_MASK) == pwm_count_cooler && (MAX_FAN_PWM & COOLER_PWM_MASK) != COOLER_PWM_MASK) WRITE(FAN_PIN, 0);
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
  • You are simply using symbolic pin names that are not defined for your board, see for example
    That is because you used HEATER_7_PIN in configuration, but your board has not defined this. Select only defined names or select the real digital pin number directly and it will compile.
    We always have only the latest a.b.x version online as this is the one with most fixes. Use github to get in between versions instead.
  • sounds good!
