TMC2130 direction and torque problem
I changed steppers from A4988 to TMC2130 (x,y,z-axis) on my Ramps 1.4. The z-axis is working fine,
but the x and y are having problems.
When home x, the direction is correct towards the x min stop, but when controlling from the host to plus (+) direction movement is continued wrongly towards x min stop. And vice versa when controlling to minus (-) direction the movement is towards x max stop.
Second problem is torque, there aren't any. The carriage barely moves and I can only control 1 mm increments, trying 10 mm only makes a noise and the carriage barely moves. Same with the y-axis. Z-axis is working just fine. Also with the A4988 I had no problems.
Any suggestions are welcome!
-> directional problem solved for x-axis (same applied to y-axis)
Not enough torque was solved by increasing the voltage from the pot. And I realized that the Watterot neede CFG5 & CFG4 to be soldered (Standalone was already open = SPI mode) for the SPI bus to come alive.
Not properly moving sensorless homing needed slight increase in sensitivity value to become less sensitive.
Thank you all those various posts and youtube videos to solve my problems:
https://www.youtube.com/watch?v=AVHVCPcFHUs
https://discuss.toms3d.org/hardware-f6/use-tmc2130-without-spi-in-stealthchop-t406.html
https://forum.repetier.com/discussion/comment/20466/#Comment_20466
So all you did was turn up the POT a little?
