Homing with Bltouch
Hi All
I just build a CoreXY (Hyper Cube Evolution) and would like to home to the top instead of the bottom by using the Bltouch (As the build height is 800 mm it would be a lot faster to home to Z-min). But if I look in the config for 1.0.0 release I can't find a way to add G-code as in auto bead leveling. And if I'm not wrong we also need the homing to subtract the nozzle-Bltouch dif.
So if I'm right in not finding it then firmware this is a feature request if I'm wrong then yer I put it in the wrong section <span>
</span>
Or I might be thinking it all wrong... <span>
</span>
For bl touch, you will also need to enable the servo support.
I can see if I go to Mechanics and enable homing order "X, Y, preheat then Z" then I get the option to put in a XY Homing pos. for Z.
I don't know if that would take the Z-probe height in to account. But that could be fixed by probing the bead after homing.
I will have to do some testing
Z probe height is used for the Z homing.
The attached images show how i have my 3d touch(bl touch clone) setup.
edit/ 1st picture,you need to set the probe X Y offsets
