Core-XY: park the nozzle to another position after G28
Hi Roland, i've Core-XY with the Y endstop to the MAX position, and after the
home I would like it not to remain in position 0 but go to a different
value, in order to have the effector where I want, in my case "front left", and not "back left" (in the default of the home).
There is no parameter in the firmware to do this thing?
Regards, Marco
Regards, Marco
In the Repetier-Host go to Config - Printer Settings - Printer. You can set a park position. You can set it up to go there after a "Job Kill" , or use the P icon under Manual Control, or it will go there after a job is finished. That is if you use Host, I do, so I have not looked at parameters in firmware.
