[DUE] Watchdog reset at startup after changing steps/mm in EEPROM
I changed my stepper driver from RAPS128 to TMC2208 on my RADDS Board, so I had to configure the steps per mm variable in EEPROM from 800 to 100 (RAPS128 were working with 128 microsteps, TMC2208 works with 16 microsteps and does an internal interpolation of a quite high resolution sinus signal for silent movement).
After that EEPROM Change, the watchdog will always reset after the next reboot for a random period of time (several minutes). The behaviour is similar to this thread:
"[DUE] Watchdog keeps resetting after power on for random amount of time"
When I disable the watchdog, the changes of my settings are working fine. I also changed the settings in configuration.h and did a recompile. It will work, until I activate the new settings in EEPROM...
Does it work with 800 steps per mm and TMC2208? Or 100 substeps with RAPS128? What I'm after is, if the driver has influence on the problem. Firmware does not know about the driver and handles them the same means as STEP/DIR/ENABLE stepper driver.
The watchdog resets will occur after the next restart (close RS232 communication and reopen communication of the host program, for example). You said that watchdog will trigger after 4 seconds. Thats strange, because the reset intervall of the software is about 1.5 sec -> see screenshot...
Both stepper driver are working as expected after the substep reconfiguration. I also think, that the different stepper driver doesn´t have any influence to the firmware, because the interface is only digital logic...
Commands::writeLowestFreeRAM();
HAL::setupTimer();
#if FEATURE_WATCHDOG
HAL::startWatchdog();
#endif // FEATURE_WATCHDOG
So watchdog was disabled until starting to write free ram. So this means that not our watchdog is triggering but the watchdog that was activated before. In fact we even disable watchdog at startup, but that only works with recent Arduino IDE versions. So what Arduino IDE did you use? Can you recompile using 1.8.x with SAM Board 1.6.11. I'm not sure when they changed this so you could decide in software how to handle watchdog.
