Print offset reset after G28 in firmware 0.92.9
I had Repetier firmware 0.92.8 in my printer, levelled bed with measuring tool, and fine tuned by setting Z-offset (which can be different with different extruder/bed temperature combinations). However afrer upgrading to 0.92.9, I had some bad prints, therefore I checked what´s going wrong, and found that if I set Z-offset to something, executing G28 (home), resets offsets to zero. Which makes it of course unusable. I returned to 0.92.8 which works as I am used to.
The solution for this now is to set bed coating to the wanted offset. That way it also stays permanent across homing requests.
