SAFETY ISSUE TEMP CONTROL!!!!!! MIN_DEFECT_TEMPERATURE >0 not working correct
i'v got a strange problem with my ramps:
using for my HeatBed Thermistor100K Honeywell 135-...
But The firmware shows only 0° IF i do NOT connect the thermistor. First i tought ok, well, MIN_DEFECT_TEMPERATURE is set to -10° so it looks like it is ok for the firmware.
So i set MIN_DEFECT_TEMPERATURE to 10° but it did not report the sensor as defective.
Why not?
I messed around little bit. Set the thermistor for the hotend to 100K NTC 3950 and the firmware reports -178.4° if i do not connect the thermistor. But as long as the MIN_DEFECT_TEMPERATURE is set to >=0 the firmware won't detect the not connected thermistor.
So
problem nr.1: MIN_DEFECT_TEMPERATURE >=0 won't trigger a not connected thermistor
problem nr.2: Thermistor type 100K Honeywell 135-.. report 0° temp on a not connected thermistor.
Can you verify/reproduce this?
Why not?
So
targetTemperatureC is initialized with 0.
So the
And the Second: the 100k Honeywell 135-104LAG-J01 Temp-Table starts at zero!?
#define NUMTEMPS_9 67 // 100k Honeywell 135-104LAG-J01
const short temptable_9[NUMTEMPS_9][2] PROGMEM = {
{1 * 4, 941 * 8}, {19 * 4, 362 * 8}, {37 * 4, 299 * 8}, //top rating 300C
{55 * 4, 266 * 8}, {73 * 4, 245 * 8}, {91 * 4, 229 * 8}, {109 * 4, 216 * 8}, {127 * 4, 206 * 8}, {145 * 4, 197 * 8}, {163 * 4, 190 * 8}, {181 * 4, 183 * 8}, {199 * 4, 177 * 8},
{217 * 4, 171 * 8}, {235 * 4, 166 * 8}, {253 * 4, 162 * 8}, {271 * 4, 157 * 8}, {289 * 4, 153 * 8}, {307 * 4, 149 * 8}, {325 * 4, 146 * 8}, {343 * 4, 142 * 8}, {361 * 4, 139 * 8},
{379 * 4, 135 * 8}, {397 * 4, 132 * 8}, {415 * 4, 129 * 8}, {433 * 4, 126 * 8}, {451 * 4, 123 * 8}, {469 * 4, 121 * 8}, {487 * 4, 118 * 8}, {505 * 4, 115 * 8}, {523 * 4, 112 * 8},
{541 * 4, 110 * 8}, {559 * 4, 107 * 8}, {577 * 4, 105 * 8}, {595 * 4, 102 * 8}, {613 * 4, 99 * 8}, {631 * 4, 97 * 8}, {649 * 4, 94 * 8}, {667 * 4, 92 * 8}, {685 * 4, 89 * 8},
{703 * 4, 86 * 8}, {721 * 4, 84 * 8}, {739 * 4, 81 * 8}, {757 * 4, 78 * 8}, {775 * 4, 75 * 8}, {793 * 4, 72 * 8}, {811 * 4, 69 * 8}, {829 * 4, 66 * 8}, {847 * 4, 62 * 8},
{865 * 4, 59 * 8}, {883 * 4, 55 * 8}, {901 * 4, 51 * 8}, {919 * 4, 46 * 8}, {937 * 4, 41 * 8},
{955 * 4, 35 * 8}, {973 * 4, 27 * 8}, {991 * 4, 17 * 8}, {1009 * 4, 1 * 8}, {1023 * 4, 0} //to allow internal 0 degrees C
You might make last entry 4095, -50 then I guess it will work, also result is not correct then, but only in that unusable area. Maybe we should add such a thing to all thermistors. Can you test if that would work so I can make the change. Unfortunately I have the wrong thermistors which go below 0 already. Question is more if that small range will be enough to detect defect then.
You can test this yourself just DISCONNECT the thermistor.
And a MIN_DEFECT_TEMPERATURE >=0 would still not work correct.
and why are some thermistor-tabels end on 0° Celcius when e.g. the Thermistor 100k Honeywell 135-104LAG-J01 works from -60° till 300°?
Sometimes you do not see the obvious:-)
The tables are older then the firmware and already were part of Sprinter which was the base. The problem at low temperatures is that resistance goes to infinity an a voltage divider made to measure on the other side of temperature scale. If you look into this
{3945, 160}, {4002, 80}, {4038, 0}, {4061, -80}, {4075, -160}
for example you see that very small changes measured cause very big changes, so that side is never reliable.
Defect is tested here (are you using dev version?)
if((act->currentTemperatureC < MIN_DEFECT_TEMPERATURE || act->currentTemperatureC > MAX_DEFECT_TEMPERATURE) &&
act->targetTemperatureC > MIN_DEFECT_TEMPERATURE /*is heating*/ &&
(act->preheatTime() == 0 || act->preheatTime() >= MILLISECONDS_PREHEAT_TIME /*preheating time is over*/)) { // no temp sensor or short in sensor, disable heater
As you see sign should not matter, only additional reason is preheat time if enabled must be up. Will test when I think on it anyway with positive MIN_DEFECT_TEMPERATURE
So the
And of course i am using DEV version
For next update I have set this to > 0 so it behaves the same.
The condition is good for printers that also swap to cnc tools, so they do not complain about defect temperatures all the time also they are not using them.
I tried the new commited version, and for the extruder it triggers "Heizelem. entkoppelt" when i change the target-temperature it is heating a short time and then it triggers.
The Sensor says -178°. It acts like MIN_DEFECT_Temperature config doesn't exists.
If i change it to act->targetTemperatureC >= 0 then it triggers immediatly "Temp.-Sensor defekt"
Tested a little around. If i set the min_heat_temp to 30 it triggers defect also on the extruder.
Looks ok for me.
