Do slicer parameters like retraction settings override firmware settings?
Repetier 0.92.9
Firmware (and EEPROM) values:
RETRACTION_LENGTH 3
RETRACTION_SPEED 40
RETRACTION_Z_LIFT 0
Slicer settings are as shown in the attached image
In such a scenario, since slicer values are higher, will they be applied or do the firmware values set the limits as 3, 40 and 0?
RETRACTION_LENGTH 3
RETRACTION_SPEED 40
RETRACTION_Z_LIFT 0
RETRACTION_LENGTH 3
RETRACTION_SPEED 40
RETRACTION_Z_LIFT 0
right?
And it won't make any difference what values I give to "Retraction Distance", "Extra Restart Distance" & "Retraction Vertical Lift" in the slicer. Right?
I understand that G1 X Y Z E will control retraction but what speed will it use for that? The one stored in EEPROM or the one specified in Slicer.
Ignore this comment. I misunderstood something.
One more thing, my extruder steps/mm are 95. It uses a 1.8 degree 1.5A motor. How do I find out the maximum retraction speed it can achieve?
