Z axis not working for Ultratronics boards
Hi There
It seems there's a problem with the Z axis not working at all for Ultratronics boards in the latest 1.0.0dev tool.
If you make changes to the firmware using the config tool and then load it, the z axis does not work.
If you bypass the config tool and make the same changes in Arduino and upload, then the Z axis works just fine
Cheers
Cheers
Can you tell what setting is wrong? Appaerently one of the z related settings is different in config tool, but which one doe snot get set correctly? You should be able to compare the config generated with manual version as both use same defines.
