Z-Axis problem with FAST_COREXYZ and two z-axis-endstops.
i am experimenting with my corexy printer. I'm using a ramps with repetier-firmware and i have two z-motors with two endstops.
The Problem: if i define FAST_COREXYZ my z-axis won't home anymore, if i move it manually in z-direction the firmware just resets.
This i find is very strange.
If i deactivate FAST_COREXYZ homing with two endstops works fine.
if i deactivate multiple-endstops for z and activate FAST_COREXYZ it is also working.
Config follows
regards
        MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
        along with Repetier-Firmware.  If not, see <http://www.gnu.org/licenses/>.
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
       This file is optimized for version 1.0.0dev
       as you expect.
    #define NUM_EXTRUDER 1
    #define MOTHERBOARD 33
    #include "pins.h"
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define BOARD_FAN_MIN_SPEED 0
    #define FAN_THERMO_PIN -1
    #undef Y_MIN_PIN
    #define Y_MIN_PIN -1
    #undef Z_MIN_PIN
    #define Z_MIN_PIN -1
    #undef X_MAX_PIN
    #define X_MAX_PIN -1
    #undef Y_MAX_PIN
    #define Y_MAX_PIN ORIG_Y_MIN_PIN
    #undef Z_MAX_PIN
    #define Z_MAX_PIN ORIG_Z_MIN_PIN
    //#define EXTERNALSERIAL  use Arduino serial library instead of build in. Requires more ram, has only 63 byte input buffer.
    //#define COMPAT_PRE1
    #define BLUETOOTH_SERIAL  -1
    #define BLUETOOTH_BAUD  115200
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 1
    #define XAXIS_STEPS_PER_MM 160
    #define YAXIS_STEPS_PER_MM 160
    #define ZAXIS_STEPS_PER_MM 800
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define KILL_IF_SENSOR_DEFECT 1
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_END_COMMANDS ""
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 100
    #define EXT0_TEMPSENSOR_TYPE 0
    #define EXT0_INVERSE 0
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 50
    #define EXT0_HEAT_MANAGER 1
    #define EXT0_PREHEAT_TEMP 190
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_I 2
    #define EXT0_PID_D 40
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0
    #define EXT0_ADVANCE_L 0
    #define EXT0_WAIT_RETRACT_UNITS 10
    #define EXT0_EXTRUDER_COOLER_PIN HEATER_1_PIN
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define FILAMENTCHANGE_Z_ADD  2
    #define JAM_METHOD 2
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 30
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    #define TEMP_HYSTERESIS 2
    #define EXTRUDE_MAXLENGTH 160
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 0
    #define COOLER_PWM_SPEED 0
    #define HAVE_HEATED_BED 1
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_SENSOR_TYPE 0
    #define HEATED_BED_HEATER_PIN 4
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME   196
    #define HEATED_BED_PID_IGAIN   33
    #define MIN_EXTRUDER_TEMP 150
    #define MAXTEMP 275
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    #define LASER_WARMUP_TIME 0
    #define LASER_PWM_MAX 255
    #define LASER_WATT 2
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    #define CNC_PWM_MAX 255
    #define CNC_RPM_MAX 8000
    #define CNC_SAFE_Z 150
    #define MULTI_ZENDSTOP_HOMING 1
    #define ENDSTOP_PULLUP_X_MIN false
    #define ENDSTOP_PULLUP_Z2_MINMAX false
    #define MINMAX_HARDWARE_ENDSTOP_Z2 true
    #define ENDSTOP_PULLUP_Y_MAX false
    #define ENDSTOP_PULLUP_Z_MAX false
    #define DOOR_PIN -1
    #define DOOR_PULLUP 1
    #define DOOR_INVERTING 0
    #define ENDSTOP_X_BACK_MOVE 10
    #define ENDSTOP_Y_BACK_MOVE 10
    #define ENDSTOP_Z_BACK_MOVE 10
    #define ENDSTOP_X_RETEST_REDUCTION_FACTOR 5
    #define ENDSTOP_Y_RETEST_REDUCTION_FACTOR 5
    #define ENDSTOP_Z_RETEST_REDUCTION_FACTOR 5
    #define ENDSTOP_Z_BACK_ON_HOME 1
    #define MOVE_X_WHEN_HOMED 0
    #define MOVE_Y_WHEN_HOMED 0
    #define MOVE_Z_WHEN_HOMED 0
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define PREVENT_Z_DISABLE_ON_STEPPER_TIMEOUT
    #define INVERT_X_DIR 0
    #define INVERT_Y_DIR 0
    #define INVERT_Z_DIR 0
    #define X_HOME_DIR -1
    #define Y_HOME_DIR 1
    #define Z_HOME_DIR 1
    #define X_MAX_LENGTH 300
    #define Y_MAX_LENGTH 295
    #define Z_MAX_LENGTH 285
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define Z2_MINMAX_PIN ORIG_Z_MAX_PIN
    #define DISTORTION_LIMIT_TO 2
    #define DISTORTION_PERMANENT 0
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 190
    #define DISTORTION_YMAX 190
    // ##                           Movement settings                                          ##
    #define DELTA_SEGMENTS_PER_SECOND_PRINT 10 // Move accurate setting for print moves
    #define DELTA_SEGMENTS_PER_SECOND_MOVE 10 // Less accurate setting for other moves
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_HOME_ON_POWER 0
    #define MAX_INACTIVE_TIME 3600L
    #define MAX_FEEDRATE_X 300
    #define MAX_FEEDRATE_Y 300
    #define MAX_FEEDRATE_Z 50
    #define HOMING_FEEDRATE_X 40
    #define HOMING_FEEDRATE_Y 40
    #define HOMING_FEEDRATE_Z 50
    #define ZHOME_PRE_RAISE 0
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 999999
    #define ZHOME_Y_POS 999999
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 1
    #define ALLOW_QUADSTEPPING 1
    #define MAX_JERK 20
    #define MAX_ZJERK 0.3
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define DUAL_X_RESOLUTION 0
    #define X2_STEP_PIN   ORIG_E1_STEP_PIN
    #define X2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E1_DIR_PIN
    #define FEATURE_TWO_ZSTEPPER 1
    #define Z2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define Z4_STEP_PIN   ORIG_E3_STEP_PIN
    #define Z4_DIR_PIN    ORIG_E3_DIR_PIN
    #define USE_ADVANCE 1
    #define BAUDRATE 115200
    #define POWER_INVERTING 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 2
    #undef PS_ON_PIN
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define SERVO0_NEUTRAL_POS  -1
    #define SERVO1_NEUTRAL_POS  -1
    #define SERVO2_NEUTRAL_POS  -1
    #define SERVO3_NEUTRAL_POS  -1
    #define UI_SERVO_CONTROL 0
    #define FAN_KICKSTART_TIME  200
            #define FEATURE_WATCHDOG 1
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 1
    #define FEATURE_Z_PROBE 1
    #define EXTRUDER_IS_Z_PROBE 0
    #define Z_PROBE_PIN ORIG_Y_MAX_PIN
    #define Z_PROBE_PULLUP 0
    #define Z_PROBE_ON_HIGH 0
    #define Z_PROBE_X_OFFSET 0
    #define Z_PROBE_Y_OFFSET -20
    #define Z_PROBE_SPEED 2
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_REPETITIONS 1
    #define Z_PROBE_HEIGHT 2
    #define Z_PROBE_DELAY 0
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 10
    #define Z_PROBE_Y1 10
    #define Z_PROBE_X2 290
    #define Z_PROBE_Y2 10
    #define Z_PROBE_X3 150
    #define Z_PROBE_Y3 290
    #define BED_LEVELING_METHOD 0
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 0
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #ifndef SDSUPPORT  // Some boards have sd support on board. These define the values already in pins.h
    #define SDSUPPORT 1
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #endif
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 11
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 0
    #define LANGUAGE_DE_ACTIVE 1
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define UI_PRINTER_NAME "HCE170912"
    #define UI_PRINTER_COMPANY "Joek.eu"
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 2
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 20
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 1
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_MIN_HEATED_BED_TEMP  30
    #define UI_SET_MIN_EXTRUDER_TEMP   140
    #define UI_SET_MAX_EXTRUDER_TEMP   260
    #define NUM_MOTOR_DRIVERS 0
    #define FAST_COREXYZ 1
    #endif
        "editMode": 2,
        "processor": 0,
        "baudrate": 115200,
        "bluetoothSerial": -1,
        "bluetoothBaudrate": 115200,
        "xStepsPerMM": 160,
        "yStepsPerMM": 160,
        "zStepsPerMM": 800,
        "xInvert": 0,
        "xInvertEnable": 0,
        "eepromMode": 2,
        "yInvert": 0,
        "yInvertEnable": 0,
        "zInvert": 0,
        "zInvertEnable": 0,
        "extruder": [
                "id": 0,
                "heatManager": 1,
                "pidDriveMin": 40,
                "pidDriveMax": 230,
                "pidMax": 255,
                "sensorType": 0,
                "sensorPin": "TEMP_0_PIN",
                "heaterPin": "HEATER_0_PIN",
                "maxFeedrate": 50,
                "startFeedrate": 20,
                "invert": "0",
                "invertEnable": "0",
                "acceleration": 5000,
                "watchPeriod": 1,
                "pidP": 7,
                "pidI": 2,
                "pidD": 40,
                "advanceK": 0,
                "advanceL": 0,
                "waitRetractTemp": 150,
                "waitRetractUnits": 10,
                "waitRetract": 10,
                "stepsPerMM": 100,
                "coolerPin": "HEATER_1_PIN",
                "coolerSpeed": 255,
                "selectCommands": "",
                "deselectCommands": "",
                "xOffset": 0,
                "yOffset": 0,
                "zOffset": 0,
                "xOffsetSteps": 0,
                "yOffsetSteps": 0,
                "zOffsetSteps": 0,
                "stepper": {
                    "name": "Extruder 0",
                    "step": "ORIG_E0_STEP_PIN",
                    "dir": "ORIG_E0_DIR_PIN",
                "advanceBacklashSteps": 0,
                "decoupleTestPeriod": 12,
                "jamPin": -1,
                "jamPullup": "0",
                "mirror": "0",
                "invert2": "0",
                "stepper2": {
                "preheat": 190
        "uiLanguage": 0,
        "uiController": 0,
        "xMinEndstop": 4,
        "yMinEndstop": 0,
        "zMinEndstop": 0,
        "xMaxEndstop": 0,
        "yMaxEndstop": 4,
        "zMaxEndstop": 4,
        "motherboard": 33,
        "driveSystem": 1,
        "xMaxSpeed": 300,
        "xHomingSpeed": 40,
        "xTravelAcceleration": 1000,
        "xPrintAcceleration": 1000,
        "yMaxSpeed": 300,
        "yHomingSpeed": 40,
        "yTravelAcceleration": 1000,
        "yPrintAcceleration": 1000,
        "zMaxSpeed": 50,
        "zHomingSpeed": 50,
        "zTravelAcceleration": 100,
        "zPrintAcceleration": 100,
        "xMotor": {
            "name": "X motor",
            "step": "ORIG_X_STEP_PIN",
            "dir": "ORIG_X_DIR_PIN",
            "enable": "ORIG_X_ENABLE_PIN"
        "yMotor": {
            "name": "Y motor",
            "step": "ORIG_Y_STEP_PIN",
            "dir": "ORIG_Y_DIR_PIN",
            "enable": "ORIG_Y_ENABLE_PIN"
        "zMotor": {
            "name": "Z motor",
            "step": "ORIG_Z_STEP_PIN",
            "dir": "ORIG_Z_DIR_PIN",
            "enable": "ORIG_Z_ENABLE_PIN"
        "enableBacklash": "0",
        "backlashX": 0,
        "backlashY": 0,
        "backlashZ": 0,
        "stepperInactiveTime": 360,
        "maxInactiveTime": 3600,
        "xMinPos": 0,
        "yMinPos": 0,
        "zMinPos": 0,
        "xLength": 300,
        "yLength": 295,
        "zLength": 285,
        "alwaysCheckEndstops": "1",
        "disableX": "0",
        "disableY": "0",
        "disableZ": "0",
        "disableE": "0",
        "xHomeDir": "-1",
        "yHomeDir": "1",
        "zHomeDir": "1",
        "xEndstopBack": 1,
        "yEndstopBack": 1,
        "zEndstopBack": 1,
        "deltaDiagonalRod": 445,
        "deltaAlphaA": 210,
        "deltaAlphaB": 330,
        "deltaAlphaC": 90,
        "deltaDiagonalCorrA": 0,
        "deltaDiagonalCorrB": 0,
        "deltaDiagonalCorrC": 0,
        "deltaMaxRadius": 150,
        "deltaRadiusCorrA": 0,
        "deltaRadiusCorrB": 0,
        "deltaRadiusCorrC": 0,
        "deltaXOffsetSteps": 0,
        "deltaYOffsetSteps": 0,
        "deltaZOffsetSteps": 0,
        "deltaSegmentsPerLine": 20,
        "stepperHighDelay": 0,
        "directionDelay": 1,
        "allowQuadstepping": "1",
        "doubleStepDelay": 0,
        "maxJerk": 20,
        "maxZJerk": 0.3,
        "moveCacheSize": 16,
        "moveCacheLow": 10,
        "lowTicksPerMove": 250000,
        "enablePowerOnStartup": "1",
        "echoOnExecute": "1",
        "sendWaits": "1",
        "ackWithLineNumber": "1",
        "killMethod": 1,
        "useAdvance": "1",
        "useQuadraticAdvance": "0",
        "powerInverting": 0,
        "mirrorX": 0,
        "mirrorXMotor": {
            "name": "Extruder 1",
            "step": "ORIG_E1_STEP_PIN",
            "dir": "ORIG_E1_DIR_PIN",
        "mirrorY": 0,
        "mirrorYMotor": {
        "mirrorZ": "1",
        "mirrorZMotor": {
        "mirrorZ3": "0",
        "mirrorZ3Motor": {
            "name": "Extruder 2",
            "step": "ORIG_E2_STEP_PIN",
            "dir": "ORIG_E2_DIR_PIN",
        "mirrorZ4": "0",
        "mirrorZ4Motor": {
            "name": "Extruder 3",
            "step": "ORIG_E3_STEP_PIN",
            "dir": "ORIG_E3_DIR_PIN",
        "dittoPrinting": "0",
        "featureServos": "0",
        "servo0Pin": 11,
        "servo1Pin": -1,
        "servo2Pin": -1,
        "servo3Pin": -1,
        "featureWatchdog": "1",
        "hasHeatedBed": "1",
        "enableZProbing": "1",
        "extrudeMaxLength": 160,
        "featureController": 11,
        "uiPrinterName": "HCE170912",
        "uiPrinterCompany": "Joek.eu",
        "uiPagesDuration": 4000,
        "uiHeadline": "",
        "uiDisablePageswitch": "1",
        "uiAutoReturnAfter": 30000,
        "featureKeys": "0",
        "uiEncoderSpeed": 2,
        "uiReverseEncoder": "0",
        "uiKeyBouncetime": 20,
        "uiKeyFirstRepeat": 500,
        "uiKeyReduceRepeat": 50,
        "uiKeyMinRepeat": 50,
        "featureBeeper": "1",
        "uiMinHeatedBed": 30,
        "uiMaxHeatedBed": 120,
        "uiMinEtxruderTemp": 140,
        "uiMaxExtruderTemp": 260,
        "uiExtruderFeedrate": 2,
        "maxBedTemperature": 120,
        "bedSensorType": 0,
        "bedSensorPin": "TEMP_1_PIN",
        "bedHeaterPin": 4,
        "bedHeatManager": 1,
        "bedPreheat": 55,
        "bedUpdateInterval": 5000,
        "bedPidDriveMin": 80,
        "bedPidDriveMax": 255,
        "bedPidP": 196,
        "bedPidI": 33,
        "bedPidD": 290,
        "bedPidMax": 255,
        "bedDecoupleTestPeriod": 300,
        "caseLightPin": -1,
        "caseLightDefaultOn": "1",
        "bedSkipIfWithin": 3,
        "gen1T0": 25,
        "gen1R0": 100000,
        "gen1Beta": 4036,
        "gen1MinTemp": -20,
        "gen1MaxTemp": 300,
        "gen1R1": 0,
        "gen1R2": 4700,
        "gen2T0": 25,
        "gen2R0": 100000,
        "gen2Beta": 4036,
        "gen2MinTemp": -20,
        "gen2MaxTemp": 300,
        "gen2R1": 0,
        "gen2R2": 4700,
        "gen3T0": 25,
        "gen3R0": 100000,
        "gen3Beta": 4036,
        "gen3MinTemp": -20,
        "gen3MaxTemp": 300,
        "gen3R1": 0,
        "gen3R2": 4700,
        "userTable0": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable1": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "userTable2": {
            "r1": 0,
            "r2": 4700,
            "temps": [],
            "numEntries": 0
        "tempHysteresis": 2,
        "pidControlRange": 30,
        "skipM109Within": 2,
        "extruderFanCoolTemp": 50,
        "minTemp": 150,
        "maxTemp": 275,
        "minDefectTemp": -10,
        "maxDefectTemp": 290,
        "arcSupport": "1",
        "forceChecksum": "0",
        "sdExtendedDir": "1",
        "featureFanControl": "1",
        "fanPin": "ORIG_FAN_PIN",
        "featureFan2Control": "0",
        "fan2Pin": "ORIG_FAN2_PIN",
        "fanThermoPin": -1,
        "fanThermoMinPWM": 128,
        "fanThermoMaxPWM": 255,
        "fanThermoMinTemp": 45,
        "fanThermoMaxTemp": 60,
        "fanThermoThermistorPin": -1,
        "fanThermoThermistorType": 1,
        "scalePidToMax": 0,
        "zProbePin": "ORIG_Y_MAX_PIN",
        "zProbeBedDistance": 10,
        "zProbeDisableHeaters": "1",
        "zProbePullup": "0",
        "zProbeOnHigh": "0",
        "zProbeXOffset": 0,
        "zProbeYOffset": -20,
        "zProbeWaitBeforeTest": "0",
        "zProbeSpeed": 2,
        "zProbeXYSpeed": 150,
        "zProbeHeight": 2,
        "zProbeStartScript": "",
        "zProbeFinishedScript": "",
        "featureAutolevel": "1",
        "zProbeX1": 10,
        "zProbeY1": 10,
        "zProbeX2": 290,
        "zProbeY2": 10,
        "zProbeX3": 150,
        "zProbeY3": 290,
        "zProbeSwitchingDistance": 1,
        "zProbeRepetitions": 1,
        "zProbeEveryPoint": "",
        "sdSupport": "1",
        "sdCardDetectPin": -1,
        "sdCardDetectInverted": "0",
        "uiStartScreenDelay": 1000,
        "xEndstopBackMove": 10,
        "yEndstopBackMove": 10,
        "zEndstopBackMove": 10,
        "xEndstopRetestFactor": 5,
        "yEndstopRetestFactor": 5,
        "zEndstopRetestFactor": 5,
        "xMinPin": "ORIG_X_MIN_PIN",
        "yMinPin": -1,
        "zMinPin": -1,
        "xMaxPin": -1,
        "yMaxPin": "ORIG_Y_MIN_PIN",
        "zMaxPin": "ORIG_Z_MIN_PIN",
        "deltaHomeOnPower": "0",
        "fanBoardPin": -1,
        "heaterPWMSpeed": 0,
        "featureBabystepping": "1",
        "babystepMultiplicator": 1,
        "pdmForHeater": "0",
        "pdmForCooler": "0",
        "psOn": "ORIG_PS_ON_PIN",
        "mixingExtruder": "0",
        "featureAxisComp": "0",
        "axisCompTanXY": 0,
        "axisCompTanXZ": 0,
        "axisCompTanYZ": 0,
        "retractOnPause": 2,
        "pauseStartCommands": "",
        "pauseEndCommands": "",
        "distortionCorrection": "0",
        "distortionCorrectionR": 100,
        "distortionPermanent": "0",
        "distortionEndDegrade": 1,
        "distortionXMin": 10,
        "distortionXMax": 190,
        "distortionYMin": 10,
        "distortionYMax": 190,
        "sdRunOnStop": "",
        "featureRetraction": "1",
        "autoretractEnabled": "0",
        "retractionLength": 3,
        "retractionLongLength": 13,
        "retractionSpeed": 40,
        "retractionZLift": 0,
        "retractionUndoSpeed": 20,
        "filamentChangeXPos": 0,
        "filamentChangeYPos": 0,
        "filamentChangeZAdd": 2,
        "filamentChangeRehome": 1,
        "fanKickstart": 200,
        "servo0StartPos": -1,
        "servo1StartPos": -1,
        "servo2StartPos": -1,
        "servo3StartPos": -1,
        "uiDynamicEncoderSpeed": "1",
        "uiServoControl": 0,
        "killIfSensorDefect": "1",
        "jamSteps": 220,
        "jamSlowdownSteps": 320,
        "jamSlowdownTo": 70,
        "jamErrorSteps": 500,
        "jamMinSteps": 10,
        "jamAction": 1,
        "jamMethod": 2,
        "primaryPort": 0,
        "numMotorDrivers": 0,
        "motorDrivers": [
                "t": "None",
                "s": "",
                "invertDirection": "0",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "invertEndstop": "0",
                "minEndstop": "1",
                "endstopPullup": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
                "t": "None",
                "s": "",
                "stepsPerMM": 100,
                "speed": 10,
                "dirPin": -1,
                "stepPin": -1,
                "enablePin": -1,
                "endstopPin": -1,
                "minEndstop": "1",
                "maxDistance": 20
        "manualConfig": "#define FAST_COREXYZ 1",
        "zHomeMinTemperature": 0,
        "zHomeXPos": 999999,
        "zHomeYPos": 999999,
        "zHomeHeatHeight": 20,
        "zHomeHeatAll": "1",
        "zProbeZOffsetMode": 0,
        "zProbeZOffset": 0,
        "zProbeDelay": 0,
        "uiBedCoating": "1",
        "langEN": "0",
        "langDE": "1",
        "langNL": "0",
        "langPT": "0",
        "langIT": "0",
        "langES": "0",
        "langFI": "0",
        "langSE": "0",
        "langFR": "0",
        "langCZ": "0",
        "langPL": "0",
        "langTR": "0",
        "accelerationFactorTop": 100,
        "bendingCorrectionA": 0,
        "bendingCorrectionB": 0,
        "bendingCorrectionC": 0,
        "preventZDisableOnStepperTimeout": "1",
        "supportLaser": "0",
        "laserPin": -1,
        "laserOnHigh": "1",
        "laserWarmupTime": 0,
        "defaultPrinterMode": 0,
        "laserPwmMax": 255,
        "laserWatt": 2,
        "supportCNC": "0",
        "cncWaitOnEnable": 300,
        "cncWaitOnDisable": 0,
        "cncEnablePin": -1,
        "cncEnableWith": "1",
        "cncDirectionPin": -1,
        "cncDirectionCW": "1",
        "cncPwmMax": 255,
        "cncRpmMax": 8000,
        "cncSafeZ": 150,
        "startupGCode": "",
        "jsonOutput": "0",
        "bedLevelingMethod": 0,
        "bedCorrectionMethod": 0,
        "bedLevelingGridSize": 5,
        "bedLevelingRepetitions": 5,
        "bedMotor1X": 0,
        "bedMotor1Y": 0,
        "bedMotor2X": 200,
        "bedMotor2Y": 0,
        "bedMotor3X": 100,
        "bedMotor3Y": 200,
        "zProbeRequiresHeating": "0",
        "zProbeMinTemperature": 150,
        "adcKeypadPin": -1,
        "sharedExtruderHeater": "0",
        "extruderSwitchXYSpeed": 100,
        "dualXAxis": "0",
        "boardFanSpeed": 255,
        "keepAliveInterval": 2000,
        "moveXWhenHomed": "0",
        "moveYWhenHomed": "0",
        "moveZWhenHomed": "0",
        "preheatTime": 30000,
        "multiZEndstopHoming": "1",
        "z2MinMaxPin": "ORIG_Z_MAX_PIN",
        "z2MinMaxEndstop": 4,
        "extruderIsZProbe": "0",
        "boardFanMinSpeed": 0,
        "doorPin": -1,
        "doorEndstop": 0,
        "zhomePreRaise": 0,
        "zhomePreRaiseDistance": 10,
        "dualXResolution": "0",
        "x2axisStepsPerMM": 100,
        "coolerPWMSpeed": 0,
        "raiseZOnToolchange": 0,
        "distortionLimitTo": 2,
        "hasMAX6675": false,
        "hasMAX31855": false,
        "hasGeneric1": false,
        "hasGeneric2": false,
        "hasGeneric3": false,
        "hasUser0": false,
        "hasUser1": false,
        "hasUser2": false,
        "numExtruder": 1,
        "version": 100,
        "primaryPortName": ""
  • Please see here for the fix on dev version:
    https://forum.repetier.com/discussion/4305/corexy-with-fast-corexyz-defined-is-failing-to-home-z#latest
    I'm working on an update that will contain this as well. I guess it also solves the dual z endstop issue.
  • I already tried this fix but didn't solve the dual z endstop problem.
    I wrote in the other tread that i have a problem with dual z endstops but the original thread poster doesn't have dual z endstops.
    I think this are two separate issues so i opened a second thread.
  • can i do something to help to debug this?
  • Since I have no corexy and no printer with dual z endstops, that would be great since I have no chance to find it on my own.
    So first things to check:
    - If compiled with ALWAYS_CHECK_ENDSTOPS false, can you move?
    - Can you move also with Z homing speed?
    - When it resets, what doe slog show as reset reason?
    - At which stage of homing does the reset happen?
    - Does M119 work or also reset?
    - Does X/Y homing also reset?
    First target must be to isolate the code part that causes a reset, so as you see you should test parts of homing seperately. Later if the bigger block is identified you will start adding output to log what position you could reach.
  • So first tests done:
    always check endstops disabled: z axis wont move or home.
    Z Homing speed and moving speed are equal.
    When homing Z in the log shows "busy processing" several times.
    M119 doesn't reset. shows for all z max and z2max L. If i trigger the endstops manually the state goes correct to H.
    x/y homing and moving is working correct.
    Offtopic: which IDE do you use for firmware developing? I'm playing right now with Visual Studio Code with Arduino Plugin and must say i'm impressed.
  • Another thing: after plugging in USB there are no resets anymore. Looks like the 5V regulator overheating on zmoves.
    But Z doesn move.
  • Visual Studio Code looks interesting. So far I used AtmelStudio which is based on VisualStudio.
    What I also see is that you need to use z2MinMax as this is used for dual z endstop testing. The z2Max seems unused so far.
    Next I see that the nonlinear version uses a different endstop testing code which does not have the second endstop test at all. I have added it locally for me, but the next update has some bigger changes so needs some testing before I can publish. If you send me a pm with email I can send you the modified motion.cpp.
  • Sorry. i meant z2minmax. didnt know there is a z2max (upcoming feature?)
    pm is on its way.
  • The new version of Repetier-Firmware (19th September 2017) solved this issue.
    Thanks for great support.
