crash when trying to slice multicolor print with cura engine
i tried to load the 3dbenchy as individual parts, it took some time as repetier host imports each bit as a group and i could not find the quick command to put all bits in the same group.
then i made up 16 extruders in repetier host and changed the colors on a few of them
i then change the colors on some of the parts of benchy and tried to slice it with cura engine and got an error
http://imgur.com/a/sKYP4
i will add more pictures in a bit, but it takes some time as i have to scroll down the error box
the problem was "fixed" by upgrading to latest version (was on 2.0.1)
is that not a fault? i have looked through layer by layer to make sure
they in a diplomatic way said that they would not change this until they had a reason for it... ie when ultimakers gets mixing hotend
side Q.... will repetier be limited to 16 virtual extruder or will the limit be higher in the future?
and what ways could there be to get arround the prime tower issue?
For prime tower you could use a postprocessor adding this or try with slic3r.
