Under Extrusion after a retract
Hello, I am having a problem were after the extruder retracts the filament and the head moves to a new place that place gets under extruded for a bit. I think the filament it being retracted farther than it's being extruded after the retract. I would really appreciate some help because I can't find a setting for this in the slicer. (I'm using curaengine)
Thanks,
Thanks,
What retraction length do you have set in the slicer atm ?
It's a directs extruder, my retract length is set to 5mm. I tried slic3r instead of curaengine and found the setting. But it's still under extruded in places. Here is a picture of a benchy I printed with the new settings, it looks the same from before I changed the setting.
Thanks for the reply.
