'TWI_CLOCK_FREQ' error when upload
In file included from sketch\Repetier.h:539:0,
from sketch\BedLeveling.cpp:107:
sketch\HAL.h: In static member function 'static void HAL::hwSetup()':
HAL.h:343: error: 'TWI_CLOCK_FREQ' was not declared in this scope
HAL::i2cInit(TWI_CLOCK_FREQ);
... (long list of errors)
exit status 1
I did try to solve it for my own but all the time when I fix one error it just give me another one...
I do have
-board: arduino due (programing) //I did try with the mega 2560 and it give me sam.h error. And USB give me same error
-port: COM X arduino mega 2560
please if more information just let me know. I do really want to have my 3D project printer working
THANK YOU
I do have
THANK YOU
#define TWI_CLOCK_FREQ 400000
I did try to verify before uploading and give me this error
exit status 1
invalid preprocessing directive #PINS_H
at the beginning. Did you delete the define somehow?
#define PINS_H
The board assignment defines the capabilities of the motherboard and the used pins.
Each board definition follows the following scheme:
ARCH_AVR for AVR based boards
ARCH_ARM for all arm based boards
that the beginning on my pin.h
don´t change the original file pins.h, if you want your own definitions , write a file "userpins.h " that contains your pins
and in configuration.h set :
#define MOTHERBOARD 999
In file included from sketch\Repetier.h:198:0,
now it is giving me different errors!!!
I am not trying to change the pin.h. I am just trying to make it work.
I try to make a new firmware on the page,
-with the Arduino 2560
-ramps v1.4 (Arduino Due with RAMPS -FD)
-display reprap 128x64
-stepper Nema17
I REALLY APRECIATE YOUR HELP GUYS!!
Sketch uses 173456 bytes (33%) of program storage space. Maximum is 524288 bytes.
No device found on COM3
An error occurred while uploading the sketch
at the end of the SDCARDDETECTINVERTED is giving me this error, sorry I thought I had it on the upper post
I did upload some basic code from the examples (led blink) and it communicate when I have the Board: Arduino mega, if I select Due it just crash and give me:
that also expains all the trouble from your previous posts.
SORRY about this misunderstood, and THANK you for your time.
probably i will be coming up with some other dumb questions <span>
