Serial COM Error
Hello, I have a Prusa i3 and the last week it was printing very nice. But now, it doesn't work anymore. I noticed when it connected with Repetier (that's what I'm using), the motors locks itself, so i couldn't move the Axis manually. But now, when I push "connect", I can move the motors. I check in the log from Repetier and it says:
"No start signal detected: Forcing Start
Serial com error:System.IO.Ports.SerialErrorReceivedEventArgs
Start"
I searched in Google about the problem, and the main cause is a baud problem. I check the baud of my port (COM 4) and it says 115200. I'm using a Sanguinololu 1.3a and I programming it in Arduino. I change the baud there and in the Repetier Host to 115200 and it doesn't works.
When I try to move the Z-Axis in the Repetier, it does very slow and doesn't move the indicate distance.
What happened here?
