No the extruder is not hot actually the extruder is not fixed to the board only the motors are wired....whats.cold extrusion and how to set it Thank you
No, that is what cold extrusion means. It allows to move extruder even if it is cold. Just for such testing purposes. Just make sure in host log that you see no "Dry run enabled" message as that would prevent extruder from working as that is what dry run means.
Thank you
