Z_MAX_PIN
Hi!
Just configured and downloaded DEV firmware and when compling arduino ide says "#error You defined hardware z max endstop without pin assignment. Set pin number for Z_MAZ_PIN"
But i did assign original max endstop pin in the firmware configurator and when i upload configuration.h to edit in configurator, it says " z max pin".
Is this a bug or am i doing some wrong?
It works with configured ver. 0.92 but not DEV firmware.
I have a Z-probe so i mounted a z max endstop after reading here on the forum that it's good to have
Everything works perfect (so far, still tweaking the settings) with ver. 0.92 regarding z-probing.
