Extruder LCD Menu
I mounted a third extruded on my RAMPS 1.4 with a 'Stepper Motor Drive Expander'
I added :
in file 'pin.h'
#define ORIG_E2_STEP_PIN 64
#define ORIG_E2_DIR_PIN 59
#define ORIG_E2_ENABLE_PIN 44
#define E2_PINS ORIG_E2_STEP_PIN, ORIG_E2_DIR_PIN, ORIG_E2_ENABLE_PIN,
in file 'configutation.h'
#define EXT2_STEP_PIN ORIG_E2_STEP_PIN
#define EXT2_DIR_PIN ORIG_E2_DIR_PIN
#define EXT2_INVERSE 0
#define EXT2_ENABLE_PIN ORIG_E2_ENABLE_PIN
#define MIXING_EXTRUDER 0
#define SHARED_EXTRUDER_HEATER 1
Everything works properly ...
But in LCD Extruder menu it appears this:
-Twice 'Temp. 2' instead of 'Temp. 3'
-When I select the Extr. 1, the case 'Select. Extr. 1' is checked and the cases 'Select. Extr. 2' and ' 3'are unchecked,
'Extr. 1' works. (Normal)
-When I select the Extr. 2, the cases 'Select. Extr. 2' and 'Select. Extr. 3' are checked,
'Extr. 2' works.
-When I select the Extr. 3, the cases 'Select. Extr. 2' and 'Select. Extr. 3' are unchecked,
'Extr. 3' works.
It seems to be a bug only in the menu.
I added :
in file 'pin.h'
'Extr. 2' works.
'Extr. 3' works.
I have no response of my problem, have I posted on bad category ?
