Manual Pause VS Filament Sensor Pause Not Working Right
Hi
So i was all happy to get my filament sensor hooked up and working, but last night a print failed, and the extruder seemed buried in the print...
Needless to say I was perplexed.... I had used the pause function many times, and had tested with the filament sensor and thought it was working fine.
Did some testing this afternoon.
My pause G code is:
G91; Set Relative positioning
G1 E-8 F1800; retract filament
G1 Z30
M104 S130
G90; return to absolute positioning
This works perfectly fine if I hit pause from Repetier Server. Head moves up 30mm, 8 mm of retraction and set the temperature down, in case its sitting for a long time till i get to it.
However, If the filament sensor detects a Jam, the extruder moves to Z30 absolute and there is about 40mm or so of retraction. Needless to say, this can break thing by jamming the extruder into the print.
Why does this happen and can it be fixed?
I am about to test with specifying a safe absolute coordinate system position, but I shouldn't have to. In general i would think short moves for the pause mean less potential error, but thats probably irrelevant.
FYI I am printing on a Kossel Clear with 0.92.9
My pause G code is:
G1 Z30
M104 S130
M601 S1
G1 Z295 X0 Y0 F2000
Pause worked fine, but on continue, it was printing way high, (I think 245, which is my max Z, didn't check so not sure)
Then i tried
M601 S1
M600 X0 Y0 Z50 E-8
I like what the filament change function is trying to do, but the intial pause Z height isn't 50 mm higher relative, and then once i click to continue printing, it goes to a Z of 245....
What in the world
I would really like to be able to use the filament sensor, but the pause isn't working like it should
Pause Code:
M401
G1 Z240 X0 Y0 F2000
M104 S130
Continue Code:
M402 F2000
Does appear to work for both manual pause and filament sensor pause, and does move the extruder to a safe position.
The move to Z240 is fine.
The move back is very very slow... It appears to move fast over to the X/Y coordinate, then very slowly all the way down to the print level Z.
Why??
Run on Pause:
M401
G1 Z245 X0 Y0 F1200
M601 S1
Run on Continue:
M601 S0
M109
M513
M402 F1200
For whatever reason, on my printer, i assure you they do not do the same thing.
I can send you my firmware files if you would like.
I am happy i got the pause to function with the above, but the pause movement takes forever.
Thanks for taking a look
