RAMPS + Full Graphic Controller: Missing entries unless using print cooling fan
Hey!
I think I found a minor bug:
Before yesterday, I used my Kossel without print cooling fan (FAN_PIN unassigned). Delta, RAMPS 1.4, Reprap Discount Full Graphics Controller, nothing fancy. Yesterday I installed a Reprap Fan Extender (connected to the Servo pins on RAMPS) and set the FAN_PIN to 6. Everything works fine, even much better than before: I now can see 1) the fan symbol (showing the actual PWM value), 2) the "Mul" value, 3) the "Buffer" and 4) the Extruder distance. 1-4 were not seen before (with the FAN_PIN unassigned).
I presume some check for FAN_PIN is exiting the LCD routine, where it only should not execute the plotting of the fan symbol?
Best!
Best!
