Custom table R1 resistor value
in Bug Reports
Hello
I just went on the online configurator to write my own thermistor table. And.. I noticed that the R1 value is 0 ohm.
Well, on almost every board I saw the resistor R1 does not exist, so I think that even in the calculations a value of 0 ohms is interpreted as "missing resistor", so 0 means use an infinite value, but for correctness sake you should write something like "0 = missing resistor". But in the end.. probably it is better to just remove the resistor completely or, better, put a checkbox to enable or disable it.
Thank you
