Temperature won't rise in software
So i bought a 3d printing kit online and assembled it.
After assembly i downloaded the repetier host software and everything works just fine
The only problem i got is that when i want to start a print it wouldn't.
The software keeps telling me that the extruder is heating up but when i touch the extruder it is hot. (some melted plastic also runs out)
It tells me that the extruder temperature is at 24.5°C.
I don't use a thermistor. I use a resistor instead because i was told this would work just fine (to trick the circuit board).
I would be glad if someone had a solution
Thanks in advance
Greetings from Austria
