Thermistors Problems - Radds 1.5 - Delta printer
Hi to you all!
I have a Delta printer
with a Radds1.5 and version 0.92.8 of the firmware
I’m having trouble with
the thermistors. It always display Def on my LCD. Everything else seems to
works, (motor heating endstop…).
I didn’t touch the
default values in the pins.h file.
My connections are the
same as this picture : http://doku.radds.org/wp-content/uploads/2015/02/RADDS_Wiring.png
  • Config is correct for T0 (outermost) so your thermistor is broken or you have it on the wrong thermistor pin connected. Measure resistance with multimeter /from connector side, should be around 100kohm) or connect it to the other pins. should be one of the outermost pins.
  • Thank for your time.
    What I have did so
    far:
    1 – Check my
    thermistor they are around 128kohm – they work
    2 – Connect them to
    other pins – All the same, didn't work
    3 - Play with the pins numbers in the config.h file - try a lot of them didn't work
    4 – Check the wires –
    All ok
    5 – The thermistor pins
    on the Radds output 3.3v
    6 – Use this code to
    check the connection: http://www.dr-henschke.de/RADDS_v12_test.zip
    - The T0 work randomly. Sometime it work but sometime when I restart the board it
    doesn’t work anymore.
    PS This morning I upload
    the 0.92.8 FW and the T0 was working, until I restart it…
    Other information : I
    am on Arduino IDE 1.6.6
    I am starting to think
    that it is my board, but if someone think about something please let me know.
    Is it possible to gain access to the 0.92.6 version? Just for luck
  • Check solderings on the radds shield. Or test voltage. One pin must be 3.3 the other 0. If both have 3.3v the board has a defect I guess since we then would always measure 3.3v. From description it sounds like it gets a contact somewhere that makes it not work and sometime it is not there and it works.
  • Turn out it was my due (which I bought from reprap.me) that was in fault.
    A big thanks to all Repetier Team great work!
  • Hello sorry for stealing this thread!
    I've got the same problem! I've tried change pins in pins.h selected the right thermistor type and measured the thermistor via the contact...
    Everything seems to be fine?
    I've checked the voltage between the ground pin and A0, A1, A2, A3, A4 pins on both arduino due and on the RADDS board itself? It shows 3.3v > GND
    I can't manage to get it working? I'm running repetier 0.92.8 and only get def / 0c on the screen?
    And a piezo screaming every 30 seconds.
    Probably warning due to the broken "thermistor"
    The only big change that I've made is that I've modded on another screen (reprapdiscount full graphic smart controller)
    That's working fine with SD card reader working to?
    What's the problem?
    I saw something about A0 pin channel 2 on the arm chip?
  • You know that the thermistor pins are not 0 and 3.3v but that there is a voltage divider with 4,7k between thermistor and A0-A4? So one side is always 3.3v and the other varies depending on resistance and that is what we measure.
    With M105 X0 you get also the raw measured values also host might swallow output as unwanted.
  • Ok but how do I know what pin configuration I should use?
    A0 is only connected to supply the thermisitor with 3,3v and the other pin is reading the resistance as you said? then it should be something wrong in the pins.h file? Wrong pin assignment?
    the firmware is made in repetier configuration tool and set to RADDS in configuration.h?
    so the pin assignment should match?
    It feels like I've tried everything? I've spent the whole weekend trying to fix it..
    And the thermistor type is set to 8
    And it's the right thermistor I'm also 100% sure that it's not shorting or is defective in any way?
    It Measured 103k ohm
  • What does M105 X0 return?
    You might use T1 instead in case the due pin is defect.
  • Nothing more then this.... :(
    21:06:01.786 : extruder 0: temp sensor defect
    21:06:01.790 : heated bed: temp sensor defect marked defect
    21:06:01.790 : Error:Printer set into dry run mode until restart!
    21:06:01.794 : Disabling all heaters due to detected sensor defect.
    21:06:01.794 : DebugLevel:14
    21:06:02.469 : wait
    21:06:03.469 : wait
  • Host filters log so you see not everything. You need the hosts file log (must be enabled) where everything gets logged.
    Bought a new Arduino due and the problem is fixed! :)
    Bought my first one from reprap.me as "Couture619" did. The China knockoff they sell seems to be the problem, thanks!
  • edited March 2016 Posts: 0
    I bought the same "china-ware" on reprap.me. I've mixed feelings about moving forward, but I found this guide on reprap.org how to fix the issue:
    http://forums.reprap.org/read.php?13,569468,631394,page=6
    Maybe it's also useful to you.
  • Hi,
    I have the exact same problem as zuxztah where the LCD screen shows defective thermistor for the heated bed (Where the Extruder thermistor works fine) and also, i get the constant annoying beeping from the LCD buzzer.
    When i connect the printer to Repetier Host, I get printer is paused error. The same problems keeps on occurring after i changed the 0.92.9 firmware a little here and there.
    NB: The firmware in question is 0.92.9 from https://www.repetier.com/firmware/v092/ (The online configuration tool). The reason why i switched to this version from my original 0.91 is to use the slightly advanced features of probing as I have tried many probes on my delta and i am now testing an IR probe from Aus3D.
    Please see that i don't have any, i mean any issues with my thermistors or hardware as when i load my old firmware 0.91 back onto the Arduino Mega, everything works just fine.
    Could someone please help on this? I tried to copy as much of the same values from 0.91 to the new 0.92.9 including pin values, thermistor table value and more.... still no luck! :(
    zuxztah said:
    Hello sorry for stealing this thread! I've got the same problem! I've tried change pins in pins.h selected the right thermistor type and measured the thermistor via the contact... Everything seems to be fine? I've checked the voltage between the ground pin and A0, A1, A2, A3, A4 pins on both arduino due and on the RADDS board itself? It shows 3.3v > GND I can't manage to get it working? I'm running repetier 0.92.8 and only get def / 0c on the screen? And a piezo screaming every 30 seconds. Probably warning due to the broken "thermistor" The only big change that I've made is that I've modded on another screen (reprapdiscount full graphic smart controller) That's working fine with SD card reader working to? What's the problem? I saw something about A0 pin channel 2 on the arm chip?
    This is my firmware (0.92.9) which is giving problems:
        MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
        along with Repetier-Firmware.  If not, see <http://www.gnu.org/licenses/>.
    #ifndef CONFIGURATION_H
    #define CONFIGURATION_H
       generator: http://www.repetier.com/firmware/v092/
       as you expect.
    #define NUM_EXTRUDER 1
    #define MOTHERBOARD 33
    #include "pins.h"
    #undef FAN_BOARD_PIN
    #define FAN_BOARD_PIN -1
    #define BOARD_FAN_SPEED 255
    #define FAN_THERMO_PIN -1
    //#define COMPAT_PRE1
    //#define BLUETOOTH_SERIAL  -1
    //#define BLUETOOTH_BAUD  115200
    #define MIXING_EXTRUDER 0
    #define DRIVE_SYSTEM 3
    #define XAXIS_STEPS_PER_MM 98.425196  //160  //80
    #define YAXIS_STEPS_PER_MM 98.425196  //160  //80
    #define ZAXIS_STEPS_PER_MM 98.425196  //160  //80
    #define EXTRUDER_FAN_COOL_TEMP 50 //45
    #define PDM_FOR_EXTRUDER 0
    #define PDM_FOR_COOLER 0
    #define DECOUPLING_TEST_MAX_HOLD_VARIANCE 15  //20
    #define KILL_IF_SENSOR_DEFECT 1 //0
    #define RETRACT_ON_PAUSE 2
    #define PAUSE_START_COMMANDS "M117 SD Paused"
    #define PAUSE_END_COMMANDS "M117 Printing ..."
    #define EXT0_X_OFFSET 0
    #define EXT0_Y_OFFSET 0
    #define EXT0_Z_OFFSET 0
    #define EXT0_STEPS_PER_MM 185.198 //370
    #define EXT0_INVERSE 1  //0
    #define EXT0_ENABLE_ON 0
    #define EXT0_MIRROR_STEPPER 0
    #define EXT0_INVERSE2 0
    #define EXT0_MAX_FEEDRATE 5 //50
    #define EXT0_MAX_START_FEEDRATE 10  //20
    #define EXT0_MAX_ACCELERATION 4000
    #define EXT0_HEAT_MANAGER 1
    #define EXT0_WATCHPERIOD 1
    #define EXT0_PID_INTEGRAL_DRIVE_MAX 140
    #define EXT0_PID_INTEGRAL_DRIVE_MIN 60
    #define EXT0_PID_PGAIN_OR_DEAD_TIME 24
    #define EXT0_PID_I 0.88
    #define EXT0_PID_D 80
    #define EXT0_PID_MAX 255
    #define EXT0_ADVANCE_K 0.0f
    #define EXT0_ADVANCE_L 0.0f
    #define EXT0_SELECT_COMMANDS "M117 Extruder 1"  //""
    #define EXT0_DECOUPLE_TEST_PERIOD 30000 //12000
    #define EXT0_JAM_PIN -1
    #define EXT0_JAM_PULLUP 0
    #define FEATURE_RETRACTION 1
    #define AUTORETRACT_ENABLED 0
    #define RETRACTION_LENGTH 3
    #define RETRACTION_SPEED 40
    #define RETRACTION_Z_LIFT 0
    #define JAM_STEPS 220
    #define JAM_SLOWDOWN_TO 70
    #define JAM_ERROR_STEPS 500
    #define JAM_MIN_STEPS 10
    #define JAM_ACTION 1
    #define PID_CONTROL_RANGE 20
    #define SKIP_M109_IF_WITHIN 2
    #define SCALE_PID_TO_MAX 0
    //#define TEMP_HYSTERESIS 0
    #define EXTRUDE_MAXLENGTH 100 //160
    #define GENERIC_THERM_VREF 5
    #define HEATER_PWM_SPEED 1
    #define HAVE_HEATED_BED 1
    #define HEATED_BED_MAX_TEMP 100
    #define SKIP_M190_IF_WITHIN 3
    #define HEATED_BED_SENSOR_TYPE 4
    #define HEATED_BED_PID_INTEGRAL_DRIVE_MAX 255 //220 //255
    #define HEATED_BED_PID_PGAIN_OR_DEAD_TIME 196 //24
    #define HEATED_BED_PID_IGAIN 33.0  //0.88
    #define HEATED_BED_PID_DGAIN 290  //80
    #define MIN_EXTRUDER_TEMP 160
    #define MAXTEMP 285
    // ##                             Laser configuration                                      ##
    automatically disabled.
    #define SUPPORT_LASER 0
    #define LASER_PIN -1
    #define LASER_ON_HIGH 1
    // ##                              CNC configuration                                       ##
    #define SUPPORT_CNC 0
    #define CNC_WAIT_ON_DISABLE 0
    #define CNC_ENABLE_PIN -1
    #define CNC_ENABLE_WITH 1
    #define CNC_DIRECTION_PIN -1
    #define CNC_DIRECTION_CW 1
    //#define ENDSTOP_PULLUP_X_MIN true
    //#define ENDSTOP_X_MIN_INVERTING false
    //#define MIN_HARDWARE_ENDSTOP_X false
    //#define ENDSTOP_PULLUP_Y_MIN true
    //#define ENDSTOP_Y_MIN_INVERTING false
    //#define MIN_HARDWARE_ENDSTOP_Y false
    #define ENDSTOP_Z_MIN_INVERTING false //true
    //#define MIN_HARDWARE_ENDSTOP_Z true
    #define ENDSTOP_X_MAX_INVERTING false //true
    #define ENDSTOP_Y_MAX_INVERTING false //true
    #define ENDSTOP_Z_MAX_INVERTING false //true
    #define min_software_endstop_x false  //true
    #define min_software_endstop_y false  //true
    #define max_software_endstop_x true //false
    #define max_software_endstop_y true //false
    #define max_software_endstop_z true //false
    #define ENDSTOP_X_BACK_MOVE 10
    #define ENDSTOP_Y_BACK_MOVE 10
    #define ENDSTOP_Z_BACK_MOVE 10
    #define ENDSTOP_X_RETEST_REDUCTION_FACTOR 3 //2
    #define ENDSTOP_Y_RETEST_REDUCTION_FACTOR 3 //2
    #define ENDSTOP_Z_RETEST_REDUCTION_FACTOR 3 //2
    #define ENDSTOP_X_BACK_ON_HOME 10 //15
    #define ENDSTOP_Y_BACK_ON_HOME 10 //15
    #define ENDSTOP_Z_BACK_ON_HOME 10 //15
    #define X_ENABLE_ON 0
    #define Y_ENABLE_ON 0
    #define Z_ENABLE_ON 0
    #define DISABLE_X 0
    #define DISABLE_Y 0
    #define DISABLE_Z 0
    #define DISABLE_E 0
    #define PREVENT_Z_DISABLE_ON_STEPPER_TIMEOUT
    #define INVERT_X_DIR 0
    #define INVERT_Y_DIR 1
    #define INVERT_Z_DIR 0
    #define X_HOME_DIR 1  //-1
    #define Y_HOME_DIR 1  //-1
    #define Z_HOME_DIR -1 //1
    #define X_MAX_LENGTH 70 //200
    #define Y_MAX_LENGTH 70 //200
    #define Z_MAX_LENGTH 466
    #define X_MIN_POS 0
    #define Y_MIN_POS 0
    #define Z_MIN_POS 0
    #define DISTORTION_XMIN 10
    #define DISTORTION_YMIN 10
    #define DISTORTION_XMAX 190
    #define DISTORTION_YMAX 190
    // ##                           Movement settings                                          ##
    #define DELTA_SEGMENTS_PER_SECOND_PRINT 200 //180 // Move accurate setting for print moves
    #define DELTA_SEGMENTS_PER_SECOND_MOVE 200  //70 // Less accurate setting for other moves
    #define EXACT_DELTA_MOVES 1
    // Delta settings
    #define DELTA_DIAGONAL_ROD 257.44 // mm
    #define DELTA_ALPHA_A 210
    #define DELTA_ALPHA_B 330
    #define DELTA_ALPHA_C 90
    #define END_EFFECTOR_HORIZONTAL_OFFSET 50 //0
    #define CARRIAGE_HORIZONTAL_OFFSET 15.0 //0
    #define DELTA_MAX_RADIUS 120
    #define ROD_RADIUS 151
    #define PRINTER_RADIUS 201  //151
    #define DELTA_HOME_ON_POWER 1
    #define STEP_COUNTER
    #define DELTA_FLOOR_SAFETY_MARGIN_MM 15
    //#define SOFTWARE_LEVELING
    #define DELTASEGMENTS_PER_PRINTLINE 24  //22
    #define MAX_INACTIVE_TIME 0L
    #define MAX_FEEDRATE_X 150
    #define MAX_FEEDRATE_Y 150
    #define MAX_FEEDRATE_Z 150
    #define HOMING_FEEDRATE_X 60
    #define HOMING_FEEDRATE_Y 60
    #define HOMING_FEEDRATE_Z 60
    #define ZHOME_HEAT_ALL 1
    #define ZHOME_HEAT_HEIGHT 20
    #define ZHOME_X_POS 0 //999999
    #define ZHOME_Y_POS 0 //999999
    #define ENABLE_BACKLASH_COMPENSATION 1
    #define X_BACKLASH 0
    #define Y_BACKLASH 0
    #define Z_BACKLASH 0
    #define RAMP_ACCELERATION 1
    #define STEPPER_HIGH_DELAY 0
    #define DIRECTION_DELAY 0
    #define ALLOW_QUADSTEPPING 1
    #define DOUBLE_STEP_DELAY 0 //1 time in microseconds
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_X 1000 //1200
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Y 1000 //1200
    #define MAX_ACCELERATION_UNITS_PER_SQ_SECOND_Z 1000 //1200
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_X 1000 //1200
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Y 1000 //1200
    #define MAX_TRAVEL_ACCELERATION_UNITS_PER_SQ_SECOND_Z 1000 //1200
    #define MAX_JERK 6.8  //20
    #define MAX_ZJERK 6.8 //0.3
    #define MOVE_CACHE_LOW 10
    #define DUAL_X_AXIS 0
    #define X2_STEP_PIN   ORIG_E1_STEP_PIN
    #define X2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Y2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Y2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z2_STEP_PIN   ORIG_E1_STEP_PIN
    #define Z2_DIR_PIN    ORIG_E1_DIR_PIN
    #define Z3_STEP_PIN   ORIG_E2_STEP_PIN
    #define Z3_DIR_PIN    ORIG_E2_DIR_PIN
    #define USE_ADVANCE 0 //1
    #define BAUDRATE 76800  //115200
    #define ENABLE_POWER_ON_STARTUP 0 //1
    #define POWER_INVERTING 0
    #define KILL_METHOD 1
    #define ACK_WITH_LINENUMBER 1
    #define ECHO_ON_EXECUTE 1
    #define EEPROM_MODE 0 //1
    #undef PS_ON_PIN
    #define JSON_OUTPUT 0
    /* ======== Servos =======
    Control the servos with
    M340 P<servoId> S<pulseInUS>   / ServoID = 0..3  pulseInUs = 500..2500
    #define FEATURE_SERVO 0
    #define SERVO0_PIN 11
    #define SERVO1_PIN -1
    #define SERVO2_PIN -1
    #define SERVO3_PIN -1
    #define UI_SERVO_CONTROL 0
            #define FEATURE_WATCHDOG 1
    #define Z_PROBE_Z_OFFSET 0
    #define UI_BED_COATING 0
    #define FEATURE_Z_PROBE 1
    #define Z_PROBE_BED_DISTANCE 4  //10
    #define Z_PROBE_PIN 18
    #define Z_PROBE_PULLUP 1
    #define Z_PROBE_ON_HIGH 1
    #define Z_PROBE_X_OFFSET 20
    #define Z_PROBE_Y_OFFSET -15
    #define Z_PROBE_SPEED 5
    #define Z_PROBE_XY_SPEED 150
    #define Z_PROBE_SWITCHING_DISTANCE 2
    #define Z_PROBE_REPETITIONS 2
    #define Z_PROBE_HEIGHT -0.75
    #define Z_PROBE_START_SCRIPT "" //"G1 Z17.5 F8000"
    #define Z_PROBE_FINISHED_SCRIPT "G28"
    #define FEATURE_AUTOLEVEL 1
    #define Z_PROBE_X1 90
    #define Z_PROBE_Y1 27
    #define Z_PROBE_X2 40
    #define Z_PROBE_Y2 -89
    #define Z_PROBE_X3 -50
    #define Z_PROBE_Y3 10
    #define BED_LEVELING_METHOD 1
    #define BED_MOTOR_1_X 0
    #define BED_MOTOR_1_Y 0
    #define BED_MOTOR_2_X 200
    #define BED_MOTOR_2_Y 0
    #define BED_MOTOR_3_X 100
    #define BED_MOTOR_3_Y 200
    #define FEATURE_AXISCOMP 1
    #define AXISCOMP_TANXY 0
    #define AXISCOMP_TANYZ 0
    #define AXISCOMP_TANXZ 0
    #define SDSUPPORT 1
    #undef SDCARDDETECT
    #define SDCARDDETECT -1
    #endif
    #define SD_RUN_ON_STOP ""
    #define ARC_SUPPORT 1
    #define FEATURE_FAN_CONTROL 1
    #define FEATURE_CONTROLLER 11
    #define ADC_KEYPAD_PIN -1
    #define LANGUAGE_EN_ACTIVE 1
    #define LANGUAGE_DE_ACTIVE 0
    #define LANGUAGE_NL_ACTIVE 0
    #define LANGUAGE_PT_ACTIVE 0
    #define LANGUAGE_IT_ACTIVE 0
    #define LANGUAGE_ES_ACTIVE 0
    #define LANGUAGE_FI_ACTIVE 0
    #define LANGUAGE_SE_ACTIVE 0
    #define LANGUAGE_FR_ACTIVE 0
    #define LANGUAGE_CZ_ACTIVE 0
    #define LANGUAGE_PL_ACTIVE 0
    #define LANGUAGE_TR_ACTIVE 0
    #define UI_PRINTER_NAME "Delta 3D Printer"
    #define UI_PRINTER_COMPANY "SFU ARDUINO CLUB"
    #define UI_ANIMATION 1
    #define UI_SPEEDDEPENDENT_POSITIONING 1
    #define FEATURE_UI_KEYS 0
    #define UI_ENCODER_SPEED 1
    #define UI_REVERSE_ENCODER 0
    #define UI_KEY_BOUNCETIME 10
    #define UI_KEY_MIN_REPEAT 50
    #define FEATURE_BEEPER 1
    #define CASE_LIGHTS_PIN -1
    #define UI_SET_PRESET_HEATED_BED_TEMP_PLA 70
    #define UI_SET_PRESET_EXTRUDER_TEMP_PLA   235
    #define UI_SET_PRESET_HEATED_BED_TEMP_ABS 85
    #define UI_SET_PRESET_EXTRUDER_TEMP_ABS   240
    #define UI_SET_MAX_HEATED_BED_TEMP 100
    #define UI_SET_MIN_EXTRUDER_TEMP   170
    #define UI_SET_MAX_EXTRUDER_TEMP   280
    #define NUM_MOTOR_DRIVERS 0
    #endif
    Since you have it from enabling it means your thermistor pin for bed is set wrong (assuming in old firmware it worked). So set it to same analog pin as in 0.91 and it should do.
