Bed Thermistor 92_8
in Bug Reports
Hello Repetier,
since you release 92.8 the bed thermistor (in both lcd and host) presents wrond temperature. If i switch to 92.6 everything is fine.
My thermistor is
My thermistor is
100k Epcos B57560G0107F000
With the same Configuration.h is fine at 92.6
I haven't change anything. I'm using the same configuration.h.
Let's say from 1.1 to 1.58 etc.
I also tested on 92.7 and it's ok. When flash the 92.8 here comes the error.
I'll check your submissions.
