[1.6.0, Delta printer, Windows] Bed height map issues
Hey!
I just migrated from Marlin to Repetier and gotta say, I am IMPRESSED!
Just a short bug report on the bed height map tool:
- The first point is measured to an incorrect height when the z-axis is not set to the firmwares Z_PROBE_BED_DISTANCE value. It measures it too high/too low according to the difference between actual z height and Z_PROBE_BED_DISTANCE. All other points are measured to the correct height. I assume a G1 command to the first point misses z height?
- Unfortunately the tool allows for illegal moves when it comes to Delta printers. One has to limit the measurement range quite heavily so that the printer wont move out of the bed.
Best,
Peter!
