Wizard menu and SD card insertion
I have noticed that if a wizard menu is open and suddenly insert sd card the sd card menu pops up.
Could this be a bug since wizards must finished by users ?
  • I guess I'd say it is a bug. Also we wanted the sd card to appear when inserted I'd also say a wizard should have higher priority.
  • I've noticed that you fixed that bug on 92.7 but id you remove the SD card while a wizard menu is present, then again it leads to the main screen.
  • Ok, will check that.
