Same problem with 0.92.6! You set the wait retract distance in "mm". But when you upload the firmware to your printer the EEPROM shows the "mm-Value" multiplied by the Extruder steps / mm you set earlier. For example: I set the "Wait retract distance" to 5 mm. The EEPROM shows a value of 2050 mm, because my steps/mm setting is 410. 5 x 410 = 2050 Maybe this is the bug because the "Wait retract distance" doesnt work for me too. The value 2050 is simply greater than the "Maximum extrusion length" in one move and thus gets ignored? After an EEPROM reset with M502+M500 the value jumps back to 2050!
For example:
5 x 410 = 2050
Maybe
