Crashing during print
I have a printer with Azteeg X3 Pro Board with Viki 2 Full Graphics LCD display
It is configured for dual z driver and dual x driver
Extruder is a cyclops single hot end dual extruder
I have attempted to print from Repetier host using Slic3r as the slice program
In every instance regardless of printing over USB or printing from SD the it crashes mid print usually within the first 10 layers
It appears to just be resetting the controller. When i look at the display it just says printer ready
I have sliced the part and run the same part with the same parameters through simplify 3d and the part prints without problems
I have no idea what is going on with repetier host\firmware or slic3r to cause this problem but i think it needs to be looked at
