Compiling error
I've a Rostock mini printer with an old version of Repetier FW, so i'm try to edit and compile the new 0.91 FW.
I'm using Arduino 1.0.5 and i'm compiling the FW for an Atmega 2560, but i'm having a lots of error while compiling...
Here the Configuration.h
And here the some error:
Can someone tell me how to resolve? Thanks.
Edit: I've use the configuration tool for create the FW and the configuration.h
ui.cpp: In member function 'void UIDisplay::adjustMenuPos()':
ui.cpp:2016:47: error: ISO C++ forbids declaration of 'type name' with no type [-fpermissive]
uint8_t mtype = HAL::readFlashByte((const prog_char*)&(men->menuType));
ui.cpp:2016:41: error: expected primary-expression before 'const'
ui.cpp:2016:41: error: expected ')' before 'const'
ui.cpp: In member function 'void UIDisplay::nextPreviousAction(int8_t)':
ui.cpp:2083:47: error: ISO C++ forbids declaration of 'type name' with no type [-fpermissive]
ui.cpp:2083:41: error: expected primary-expression before 'const'
ui.cpp:2083:41: error: expected ')' before 'const'
ui.cpp:2087:49: error: ISO C++ forbids declaration of 'type name' with no type [-fpermissive]
uint8_t entType = HAL::readFlashByte((const prog_char*)&(ent->menuType));// 0 = Info, 1 = Headline, 2 = submenu ref, 3 = direct action command
ui.cpp:2087:43: error: expected primary-expression before 'const'
ui.cpp:2087:43: error: expected ')' before 'const'
Errore durante la compilazione
