Repetier doesn't start after unplugging second screen.
Hi, I installed an external LCD for my laptop, and was using repetierHost software on that. (setup as an extension)
then I was trying to start repetierHost without the second LCD it didn't start.
Unfortunately I cannot paste the error, since I've solved removing the repetier windows-config file, inside the .mono directory.
is it a known problem, or a little bug?
Thanks, Davide.
