radds 1.5 thermister problem
hey guys.
maby some other people have the same problem but i have a problem with the 100k epcos thermistor with radds 1.5 running on 24 volts.
themps are reading normal until i heat up the hotend at around 90 degrees, then i see the themp is going to stabilize and around 110 it stops going up, when i look at my hotend, ABS is oozing out wich has a temp arround 245.
first i thought it would be my temp sensor replaced it, but stil got the same reading. (did also added some themal paste, but still the same reading)
did the thermistor table changed some how or does someone has a idee what is happening here,
what i did so far at problem solving .
dismounted the cooling fan, heated the hotend to see if that had any effect, none
changed sensor, no effect
used other wiring, no effect
added thermal paste, no effect
what i am currently running,
repetier 92.9 diamond hotend setup
radds powered with 24 volt,
power supply 24 volt 16.7 amp
#elif NUM_EXTRUDER == 1
which should be
#elif NUM_EXTRUDER == 1 || MIXING_EXTRUDER
to show raw values also for mixing extruders.
Hope that gives more insight.
im going to make a table of the datasheet, i still dont know what is happening here. the only thing i see is when i do a emergency stop temps shoot up to 65 degrees and then come down to 21.
could this mean faulty board?
8-} so.........
i found the problem.......... 8-} dumb me..... radds 1.5 has 4k7 resistors already on the board
