Ramps 1.4 bluetooth
in Motherboard
Hi i have a problem with ramps 1.4 and bluetooth. I connected my hc 06 bt to D1 and D0 pins in AUX1. I tried also 115200 and 38400 baudrates. When i connect with my printer via bt in repetier host my pc is pairing with bt device and repetier host show that it is connected but i don't have any data. In host i can only read "no start signal detected - forcing start". I tried switching RX and TX cables but it doesn't working too. In repetier firmware config tool in bt serial port i choose serial 1. Is it correct ? Do you have any ideas why this bt doesn't working ?
