Homing my Geeetech G2S Pro - Z OK but X and Y lag behind.
Hi Everyone,
Been trawling the forum for some time but can't find my specific issue.
I have been using Marlin without issue, but want to upgrade to Repetier.
I've entered in all the measurements of my G2S, pretty much straight from Marlin as it's been printing fine.
However, when I hit HOME button the printer will Hit all the end stops as you would expect, however the Z slider is a lot higher than the X and Y slider.
I've tried playing with the different settings in the ENDSTOP values, but to no avail. It does not seem to matter what values I put in here, Z is triggered (Pulled High) but X and Y never get back to the Microswitch, leaving a gap of about 13mm,
M114 reports that X0 Y0 and Z206
M119 reports Z H and X and Y both L
My Endstop code currently has the defaults set to 10 for all axis.
Can you give me some pointers to what values I must change so that X and Y line up with Z when Homed? Thank you.
