1.0dev shoots too much filament
I have tryed the new dev version of the firmware and finds that it shoots to much filament. I had to ajust it down to about 82%. Then I change back to 0.92 with the very same setup, it the ran find at 100%.
  • Haven't seen this happening. Have you compared if the steps per mm have changed? Maybe the upgrade copied configuration.h values over adjusted eeprom values?
