AUTOLEVEL - Homing with Z-PROBE and Servo
I want change from Marlin to Repetier but i have a problem.
Marlin can use z-probe as z-min because the servo react automatically on a homing command.
repetier manual say: if i use z-probe with a servo then i shall have NOT Z-Min Endstop ONLY a Z-Max Endstop.
My Z-Axis is 600mm long - it´s can be not true that i must go down 600mm only for homing ????
Is there another solution? - maybe with z-min endstop ?
