[Newbie][Prusa i3 steel frame] Z axis moves really slow and doesnt go all the way up
Hello everyone, my name is Mariano and i am configuring my P3Steel using RAMPS 1.4 (drivers Allegro A4922) and NEMA 17 1.8° 1.7A.
I make everything work ok (heated bed, extruder, X and Y axis) but Z axis is moving really slow, and doesnt go all the way up. its only getting 1/10 of its height approximately.
I tried changing several configuration in firmware but no results.
Does anyone had the same problem? I appreciate your help.
Thank you very much
Thank you very much
Im changing to Marlin.
i have a prusa i3 from http://www.aliexpress.com/item/Black-Factory-High-Quality-Precision-Reprap-Prusa-i3-DIY-3d-Printer-kit-with-2-Rolls-Filament/32357171936.html?spm=2114.13010608.0.97.XNc17K
and put a ramps 1.57 to use and i can't find what values are the best to use on my configuration. would be great if anyone already had the settings and share with us.
